sark.inc wrote:how the **** did i forget that
AE101r 1996 corolla, built here in NZ. >_<
Engine is a 4age ST transplant, everything else seems to work bar this one connector causing problems.
touge_ae101 wrote:nah power for ecu should come through loom from the fusebox. should have a B1 and B+ wire that should come through the loom. thats how it is on BT anyway.
yeah i'm pretty sure that relay runs fuel. should be already switched by the ignition/ecu so no need to add an extra switch.
have you been on bill sherwoods page?he has awseom documents on the Silvertop wiring system.
