I think I screwed up badly and the valves may have hit the piston when I was turning the cam around and then broken when cranking, so I'm going to have to repair this now.
I see this as an opportunity to upgrade as this engine has higher lift cams and stiffer springs than factory so I might have problems with the factory valves in the future anyway.
So should I replace the valves with new factory ones or find some aftermarket stronger valves?
If aftermarket, who makes replacements for the 20valve?
Also, who, preferably in wellington, but if they are really good i'm willing to post the head, can install new valves and do some porting and a valve 3 angle job at the same time? Oh, and also repair the damage to the head.
Cheers.
