4agze alternator
4agze alternator
Postby ryanfels » Tue May 18, 2010 1:59 pm
Ok so i think my alternator is poked and i did a search and i couldnt find anything so i just want to check, are 4agze alternators the same as your normal 4age ones?
thegreatestben wrote:It's lucky you arent a douchebag other wise I wouldn't help you :wink: :wink:
mark 2 gx61 2jzgte powered - viewtopic.php?t=72619&start=0
Discussion - viewtopic.php?t=72620
ryanfels
Postby levinguy » Tue May 18, 2010 2:09 pm
nope, the bottom part is wider on the 4agze ones.
levinguy
Postby ryanfels » Tue May 18, 2010 2:24 pm
oh well in that case :) viewtopic.php?p=787172#787172
Thanks
ryanfels
Postby matt dunn » Tue May 18, 2010 7:48 pm
levinguy wrote:nope, the bottom part is wider on the 4agze ones.
And the rotor shaft is longer and the front bearing is heavier,
and yes the brackets are different.
