St215 Caldina Issue...
Postby CRUEL » Tue May 18, 2010 5:54 pm
hey guys! hELP ME
Have you ever come across... On the Left Front inner CV on the drivers side... it has alot of play in it wher it goes in2 the g/box, its also leaking a lil bit of oil... ive orderd a seal.... but would it of damaged the Spline on the axel at all or nah??
Cheers Rian
CRUEL
Postby sark.inc » Tue May 18, 2010 8:25 pm
sounds like somethings broken.
sark.inc
Postby cedwards » Tue May 18, 2010 11:25 pm
how much is alot of play?
they have a few mm's normally to my understanding..
cedwards
Postby KinLoud » Tue May 25, 2010 9:39 pm
I have seen something like this in a 20v ae101 gearbox...
The guy I got it off complained about it always leaking oil.
The drive shaft was loose in the gearbox
When I pulled it to bits I found that the centre of the diff (that the crown wheel bolts to) was worn where the drive shaft went through to engage diff gears!
The guy says "ahhh, that was the side that the wheel would always spin when doing burnouts!"
I doubt this will be your problem though (i hope)
Ken
Postby CRUEL » Sat May 29, 2010 7:15 pm
The caldina does the same thing, spins the Left Front wheel!!
CRUEL
