st205 wheel spacer
st205 wheel spacer
Postby ihavelift » Wed May 19, 2010 4:37 pm
hey all, so ive had a problem with the mags i'm running needing spacers to clear the calipers which push the rim out too far, and the 225 tyres rub on the guards under hard cornering/bumps.
went to autolign on lincoln road this afternoon, the guy i spoke to said i am running "inch" spacers (35mm approx?), with a 5x100 pattern.
He used some device to measure this and that, and said i can go to a 5x100 15mm spacer. Can anybody say if this is right or not? seems like a bit of a drastic jump and there is about 13-14mm space between the rim spoke and the caliper as it stands now. Anybody able to shed some light on this?
Here's a couple of pics if it helps (needs clean asap haha):
Current: 2000 Honda Accord Wagon CF6
Previous: 97 Toyota Celica GT4 ST205; 2001 Toyota Allex RS180, 96 Nissan Sentra SG
Low, Slow, Clean and Mean
ihavelift
Postby xsspeed » Wed May 19, 2010 5:03 pm
Do you have a cert for your spacers?
Max certable for boltin spacers iirc is 25mm which also = 1 inch
Postby ihavelift » Wed May 19, 2010 5:08 pm
so if i get narrower ones it can't be certed?
and no not certed, never been a problem so not bothering with it
ihavelift
Postby touge_ae101 » Wed May 19, 2010 5:10 pm
that would make sense, inch = 25mm, 25-10= 15, so you will still have 3mm clearance between caliper and wheels. :D
touge_ae101
Postby ihavelift » Wed May 19, 2010 5:12 pm
ok cool, my conversion was all messed up, in my mind 1 inch = 35mm haha.
all good.
What about the 5x100 part? what is standard stud pattern on an st205?
Am i after 15mm 5x100 spacers? if so where can people suggest i get them? would rather not try trademe - don't like using it for things on my car, always a bit too risky
ihavelift
Postby sergei » Wed May 19, 2010 5:16 pm
ihavelift wrote:ok cool, my conversion was all messed up, in my mind 1 inch = 35mm haha.
all good.
5x100 is GT4 pattern.
standard offset is 48 with 7 1/2 " wide rims
Postby ihavelift » Wed May 19, 2010 5:21 pm
thanks sergei, just got quoted $400 for a set of 5x100 15mm spacers - what a joke! I'm looking at these and thinking that might be a good route (yeah i know, tardme, but meh)
http://www.trademe.co.nz/Browse/Listing ... ermanent=0
what do you think?
ihavelift
Postby touge_ae101 » Wed May 19, 2010 5:28 pm
both DPR and CPA in wellies do wheel spacer made from billet steel. they would be my pick.
Edit: get hold of Al at driven he will sort you out their products are of decent quality in my experience. think they might even be a TS sponsor so :lol:
at a guess i doubt they would be 400bux though!
touge_ae101
Postby ihavelift » Wed May 19, 2010 5:30 pm
what are those 2 names mate? i'll look them up and give them a call
ihavelift
Postby touge_ae101 » Wed May 19, 2010 5:31 pm
touge_ae101
Postby ihavelift » Wed May 19, 2010 5:48 pm
muchas gracias
ihavelift
Postby ihavelift » Wed May 19, 2010 6:00 pm
just so i don't make a mistake, does anybody know what stud pattern these rims are? 5x100, same as the st205 stud pattern? or am i after adapter spacers to 5x114.3 or something?
here's a better pic of the mag:
They're advans, but not sure what model
ihavelift
Postby 1I1 » Wed May 19, 2010 6:02 pm
Advan RG's
TRD Clicky >>Here
1I1
Postby touge_ae101 » Wed May 19, 2010 6:06 pm
when you take those spacers off the front you should chuck them on the rear!wheel looks a bit lonely from this angle, needs to get up close and personal with panel!haha
google is your friend:
Toyota Celica GT4 ST205 facts and figures
Inducer size, 48mm, The largest of all the GT4 turbo inducers. Inducer configuration, Twin 5 blade ... Wheel stud pattern, 5 x PCD 100, Studs are M12x1.5mm ...
Specifications - Engine - Transmission - Turbo
touge_ae101
Postby ihavelift » Wed May 19, 2010 6:09 pm
haha yes that is what i am wanting to do! i think it looks lonely too, will need to roll the guard though.
so what's the stud pattern on an advan RG? 5x100 or 5x114.3?
ihavelift
Postby touge_ae101 » Wed May 19, 2010 6:13 pm
:lol: :lol: glad to hear!
depends, RG, like most wheels are made in a variety of different stud patterns and offsets. can get 4x114 etc etc. easiest thing to do is to go and measure the wheel nuts centre to centre (as accurately as you can)
but you should easily be able to figure it out cause it will be either 5x100 or 5x114.
touge_ae101
Postby ihavelift » Wed May 19, 2010 6:16 pm
sweet. you're a legend mate, shank you!
ihavelift
Postby touge_ae101 » Wed May 19, 2010 6:16 pm
i'd say you could get away with another 25mm in the rear without rolling gaurds. 25mm isn't much when you look from a distance.
even if you get slight rubbage just sort it out with a heat gun and a soft rubber mallet. :lol:
touge_ae101
Postby ihavelift » Wed May 19, 2010 6:18 pm
fyi 5x100 :D
and as for rears, we can always see what needs to be done
ihavelift
Postby touge_ae101 » Wed May 19, 2010 6:20 pm
google FTW!
touge_ae101
