Water temp flucuations - not theremo stat
Postby allencr » Sat May 22, 2010 3:31 pm
gleem wrote: I know this shouldnt be right
I don't know that! Isn't your radiator supposed to remove heat from the water coming into it so that the water exiting the bottom hose is much cooler, just like mine does?
allencr
Postby gleem » Sat May 22, 2010 4:41 pm
from my knowledge hot water from going through the engine goes out the bottom and gets sucked in the top after cooling while passing through the radiator etc
gleem
Postby Mr Revhead » Sat May 22, 2010 5:42 pm
Now, heat rises.... Why would it flow like that?
Does it reach the correct temp quickly?
Does it hold a stable heat and not fluctuate?
Postby matt dunn » Sat May 22, 2010 6:59 pm
gleem wrote:ok. put a new tgp thermo stat in and now it gets up to tempreture but the top hose gets really hot and bottom hose not at all? at normally operating tempreture. half way. I know this shouldnt be right
Yes that is the way it should be.
the water going to the radiator is hot, and the water coming from the radiator is cold,
that makes sense.
The 20V tkes the cold water in the end of the head so it flows across all the inlet ports, and then out the intake side of the head and into the back of the water pump.
and it flows out the exh side of the head to the radiator.
So it was a dud thermostat after all.
What was the subject line of this thread again?
oh yeah,
Re: Water temp flucuations - not theremo stat
Postby Lloyd » Sat May 22, 2010 7:39 pm
gleem wrote: old one workes fine but the rubber seal was a bit worn and wouldnt completly seal when closed
If it doesn't seal completely then that defines it as being broken. It doesn't take much for them to not get an engine up to temp
Postby gleem » Sun May 23, 2010 1:27 am
well im sorry, now i know that if its no tgp i might be broken from brand new. it was the thermostat after all.
gleem
Postby BZG Wagon » Sat May 29, 2010 9:41 am
gleem wrote:well im sorry, now i know that if its no tgp i might be broken from brand new. it was the thermostat after all.
I had two cheapies from repco fail on my corolla - ended up getting my money back and buying one from Toyota Parts.
3 Thermostat replacements in 4 months - like you I kept wondering if it were something else!
BZG Wagon
Postby sergei » Sat May 29, 2010 10:11 am
I had similar issues with Trident. Now I only use TGP.
