How to get an engine to warm up faster?
Postby Burning Angel » Thu May 27, 2010 6:15 pm
this morning i let it idle for 10 min before i left, its a high idle 'cause of the auto-choke. the gauge reached just over 'C'.
after work today i whipped out the thermostat to check if there were leaks around it, there were none as i had used Loctite 518 to seal it but water was coming through the jiggle pin. so ive siliconed up the jiggle pin and around the thermostat so no water can get past till the themostat opens.
demisting the windows is the primary goal, but compared to other(newer) cars ive driven its very slow to warm up.
ill give the window a clean as per strx7's instructions and ill see how it warms up 2morrow now ive sealed it up.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby sark.inc » Thu May 27, 2010 6:59 pm
sounds like a wrong or borked thermostat.
Pot of cold water + string + element = test.
sark.inc
Postby Dell'Orto » Thu May 27, 2010 7:24 pm
Just drain half the coolant, it'll warm up real quick :lol:
Postby dusk93 » Thu May 27, 2010 8:07 pm
Dell'Orto wrote:Just drain half the coolant, it'll warm up real quick ;)
^^ that and maybe add some salt ;) it works for cooking potatoes and boiling eggs :P :twisted:
strx7 wrote:if you are only worried about demisting your windows. give the windows a bloody good clean, mix up some detergent with a little water, smear it all over the inside of the windows, let it dry, buff it off, hey presto no fogging up........
+1
Current: 1983 AA60 Coupe, 1987 E30 318i coupe, 1985 SA70 Parts Heap, 1990 R32 GTST Coupe
Ex: 1982 AA60 Coupe, 1987 AE92 FXGT (RIP), 1989 Mazda Astina BG hatch, 1994 R33 Skyline GT ( RB20E powered :( )
dusk93
Postby Bling » Thu May 27, 2010 8:12 pm
BHG
Someone had to... Steve must be busy.
But seriously, I never idle anything I drive to warm it up, driving it semi-nice seems to warm it up the fastest, get the oil pumping too. Wouldn't have thought long idling would be good for it.
Postby Burning Angel » Thu May 27, 2010 8:33 pm
BZG|Bling wrote:BHG
ha lol, i was waiting for the BHG lol. but i replaced that last year(not cuz it was blown tho, it was leaking oil where the oil feed goes to the headbolt)
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby pc » Thu May 27, 2010 10:09 pm
Block off the radiator and wrap the engine in insulation... the car would only be good for driving for 5 minutes from cold though :lol:
You could install an electric heater/blower and get warm air from start, this may require a bigger alternator though. I think some flasher cars have electric heaters so maybe parts off a wreck could work.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby sark.inc » Fri May 28, 2010 1:32 pm
pc wrote:Block off the radiator and wrap the engine in insulation... the car would only be good for driving for 5 minutes from cold though :lol:
none of the new ones do that i know of, they just take heat of the exhaust.
sark.inc
Postby 1I1 » Fri May 28, 2010 2:05 pm
Piece of card blocking the radiator... drive for X minutes then pull over and remove 8)
TRD Clicky >>Here
1I1
Postby frost » Fri May 28, 2010 2:30 pm
my bmw does, instant heat from vents and seats and steering wheel, and hot/cold fridge,
could the cause be from blocked water jackets/passages in the engine?
Postby Burning Angel » Fri May 28, 2010 4:45 pm
frost wrote:could the cause be from blocked water jackets/passages in the engine?
That was a possibility i considered and due to the age of the engine quite likely. I may have to run a radiator flush through it a few times and see what happens.
blocking off the jiggle pin seems to have made a slight improvement in warm up time.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
