4age throttle body - quick question
Postby Quirky » Sat May 29, 2010 7:08 pm
All the pipes at the bottom which attach to the coolant,
If they aren't connected, is it ok to just leave it? Or should I plug them with a cap? Is it possible for 'boost' to leak out of there if they aren't plugged up?
Hello There
Quirky
Postby d1 mule » Sat May 29, 2010 7:25 pm
it wont run properly without the coolant in it , will "hunt" at idle
d1 mule
Postby Quirky » Sat May 29, 2010 7:33 pm
Car is using an aftermarket ecu, so the car idles fine.
Just wondering if it is possible for air to escape from there.
Hello There
Quirky
Postby l1ttle_d3vil » Sat May 29, 2010 10:04 pm
yes some will cause a vacuum leak, so block them off separately.
You can remove the whole idle-up valve off the throttle body and bolt a plate to it to cover it all up, then just block off the two lines left there. never had problems idling without it on standard or aftermarket ecu's.
Postby frost » Sat May 29, 2010 10:14 pm
if its the two coolant ones its ok to leave them,
just think about it "coolant" why would air be coming from the coolant system,
Postby Bling » Sat May 29, 2010 10:25 pm
BHG :wink: Otherwise yeah i'd be worried about air mixing in with coolant :lol:
Postby ChaosAD » Sat May 29, 2010 10:49 pm
The ones for power steering etc should be blocked off it not used. The coolant ones wont matter.
ChaosAD
Postby tsoob » Sun May 30, 2010 12:12 am
mine are not covered. you may find inside the butterfly there is one small hole that can leak air.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
