Any help and advice much appreciated
Tyler
sergei wrote:Let me guess: the transfer case is hitting the block in some way.
You will need to turn the gearbox along the crank axis ~15' clockwise, slide it in so it is touching the locating pins, and turn it back up.
It is very fiddly.
I hope you are not doing it in the car?
Last time I was doing it myself, and I had to put engine crack pulley down, so the engine was sitting vertical (make sure you have some wood blocks in strategic places) and place the box on top and fiddle with it for a while until it "fell" in place.
Boosted_162 wrote:sergei wrote:Let me guess: the transfer case is hitting the block in some way.
It is very fiddly.
Good advice, thats how i did mine. Spent hours with it on the ground, stood it up and had it on in 5 mins.
make sure you don't force bolt it. As it might bend the clutch disk.loudstealthGT-Four wrote:ok got it on, well not completely still got to go on another 50mm. I stood the engine up on its end and lifted the GB on top of it using the engine crane. then because the crane was in the way i unhooked it from the GB and man handled it and then... it fell over
opps.... didnt damage anything... fingers crossed
given up for now, too cold. Will resume later and try and get it on completely and bolted up and ill be
tech128 wrote:i used to grind a few places that touched just a little nt 2 much
and made it heaps easyer also had a spare input shaft that i used 4 alighnment
is it a multi clutch or single
celica_xr9145 wrote:So when do you plan on having it running again?
