How do you do this to a pipe?
Postby ATAl » Sun May 30, 2010 5:14 pm
I have some bundy pipe and want to cut it down then add a bump in the pipe like the one shown in the pic so that I can attach a water pipe, what tool is needed to do this?
ATAl
Postby touge_ae101 » Sun May 30, 2010 5:26 pm
could probably get away with just using a decent hoseclip.
other than that you can add a weld around the end of the pipe by putting heaps of wire into it. or MIG would probably be easier.
orr just cut the end off another pipe and weld it onto the one you want it on?
touge_ae101
Postby Stott69 » Sun May 30, 2010 5:33 pm
flaring tool. Pipe fitters or plumbers would have one. What size pipe is it?
Image jzs147 Aristo money pit
Stott69
Postby ATAl » Sun May 30, 2010 6:34 pm
I have two separate pipes, one is 5mm ID, 8mm OD, the other 7mm ID, 10mm OD.
ATAl
Postby Quirky » Sun May 30, 2010 8:05 pm
yep flaring tool, basically a ball bearing which when screwd makes a bulge in the pipe.
DIY project invloved flaring 10 pipes. I was dead at the end of the day...but with much larger arms...
Hello There
Quirky
Postby Stott69 » Sun May 30, 2010 8:50 pm
Il ask the guys at work if we have one I can borrow and get back to you
Stott69
Postby edwagon » Sun May 30, 2010 9:36 pm
A flaring tool will do the end flare (more like brakelines), but the tool you probably actually want is a crouxing tool - plumbers use them.
edwagon
Postby ATAl » Sun May 30, 2010 10:07 pm
Thanks heaps, but are you in welly or palmy? Might be a bit far to go to palmy to get a tool :D
What is this tool? I googled it and got nothing...
By the way, I want to make the bulges in the pipe, not flare out the end.
ATAl
Postby frost » Sun May 30, 2010 10:42 pm
the right tool is the plumbers one, but quite expensive to buy for just a few turns. you better of taking to some where for them to do it for you like power steering shop or hydralink etc,
Postby 85AW20v » Sun May 30, 2010 11:18 pm
Plumbers use a crox tool but it won't come in the sizes you want. It's used on copper pipe with ID's of 12mm, 18mm and 23mm - more commonly known as 15mm, 20mm and 25mmcopper. You can get bigger ones but only larger companies that do commercial jobs will have them.
See ya
Simon
85 MR2 20v
85AW20v
Postby Stott69 » Tue Jun 01, 2010 7:50 pm
In palmy, but in welly most weekends
Stott69
Postby ATAl » Tue Jun 01, 2010 9:41 pm
Ok, that makes sense then.
Let me know if you can borrow the tool, that would help heaps. Cheers.
ATAl
Postby GT4-Addict » Tue Jun 01, 2010 10:05 pm
Could you get a pipe with slightly thicker walls than you need and lathe it down into that shape?
GT4-Addict
Postby ATAl » Tue Jun 01, 2010 10:42 pm
Wow that's a hard way to do it :D
No, it wouldn't work, the pipe is about a meter long and bends around a lot so it would never work on a lathe.
ATAl
Postby GT4-Addict » Tue Jun 01, 2010 11:13 pm
Not even if you were just lathing a groove into the tip in order for it to make the "notches" for the hose to slip onto?
GT4-Addict
Postby Bling » Wed Jun 02, 2010 12:04 am
Weld a bead on :lol:
Postby AE25 » Wed Jun 02, 2010 4:03 pm
http://www.blmarshall.co.nz/shop.php/pl ... a76f3727f8
if only you could get the correct size eh?
how about find a factory bit of pipe that has the barbs.. and braze or weld it on the end of your pipe. then paint or get it gold passivated heh.
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Postby frost » Wed Jun 02, 2010 6:21 pm
BTW, you dont really need the bump on the inner part, its only there to stop the hose from slipping UP the pipe, and that is very unlikely, only if your clamp was loose would it move,
just flair the end and be done,
Postby ATAl » Wed Jun 02, 2010 9:15 pm
Yip not worried about the pipe slipping up, just worried about it coming off, wouldn't a flare eventually cut through the pipe?
ATAl
Postby frost » Wed Jun 02, 2010 11:54 pm
not if you use the proper tube cutting tool, instead of hack saw,
it looks like a monkey wrench but with a round blade on it,
you spin it round the tube a few times and it snaps off real clean,
you should be able to find these tools at auto shop or hardware shop,
not too badly priced for both cutter and flaring tool,
