I think my alternator/regulator is blown?
Postby cat007 » Sat Jun 05, 2010 12:14 pm
Hey all
My alternator on my 4Y powered Hiace appears to have shat itself.
I think it stemmed from driving through a big puddle but I can't be sure.
Symptoms are:
Not charging (battery warning light on)
Overcharging (battery warning light on and alternator pumping out about +16 volts)
I assume it's the regulator, not the alternator but I assume they're an all in one package?
So should I look for an alternator or a regulator?
Hunt
Postby MR2BOY23 » Sat Jun 05, 2010 12:21 pm
Afaik it's an external regulator
I found this picture
Will measure 17~ volts without regulator
If it's looking anything like that then it needs to be replaced and should fix your problem
MR2BOY23
Postby cat007 » Sat Jun 05, 2010 12:40 pm
Thank you for that. Where would that be located do you think?
Postby sergei » Sat Jun 05, 2010 2:09 pm
cat007 wrote:Thank you for that. Where would that be located do you think?
By looking at pic, it should be on the alternator, on a side, close to back side, since there are brushes sticking out of the thing.
Postby cat007 » Sat Jun 05, 2010 2:14 pm
Sorry - didn't realize they were brushes :P
Cool thanks for that. Now I'll just have to find one. Reckon that's something a parts store like repco etc would stock?
Postby MR2BOY23 » Sat Jun 05, 2010 2:37 pm
Yeah they can order them in for you
MR2BOY23
Postby cat007 » Sat Jun 05, 2010 2:42 pm
MR2BOY23 wrote:Yeah they can order them in for you
Yeah - was hoping you wouldn't say that. Kinda wanted to use the van this weekend haha. I guess I'll just take the charging lead off the alternator so it doesn't kill the batteries and charge em up after each trip haha
Part master can order them in, so I'll get the details and it should arrive by Tues-Wed....dam lol
Postby MR2BOY23 » Sat Jun 05, 2010 3:07 pm
If you need it this weekend you could try nick a part or toyotas galore
MR2BOY23
Postby Dell'Orto » Sat Jun 05, 2010 4:54 pm
Could have tried an Appco branch, they stock auto electrical bits.
Postby sark.inc » Sat Jun 05, 2010 6:05 pm
Dell'Orto wrote:Could have tried an Appco branch, they stock auto electrical bits.
generally if appco have it, repco can just get it off them, or send you down to them.
sark.inc
Postby matt dunn » Sat Jun 05, 2010 6:57 pm
I would place a bet that your regulator will not look anything like that,
unless your van is Australian assembled.
that is a Boch type reg and are classed as an internal regulator,
as it is part of the alternator.
You will be looking for a much larger metal box,
like 5 cigarette packets on top of each other size,
probably behind the glove box.
Or it may be an actual internal regulated alt, and it needs to be disassembled to get to the regulator,
But since you got it wet and it stopped,
my bet would be a fault in the alt. not the reg,
but all guesswork at this stage.
Postby Dell'Orto » Sun Jun 06, 2010 1:34 pm
Generally the Repco staff dont know part numbers for electrical bits to look them up ;)
Postby cat007 » Thu Jun 24, 2010 8:32 pm
Hey all
Still haven't fixed this yet.
Looking at the alternator I can't tell much lol - but from this link:
http://www.toyodiy.com/parts/p_G_1987_T ... _1903.html
It appears kinda small but I cant see it anywhere in the engine bay. I'll have a look behind the middle seat kick panel (under the stereo) as there's fuses and stuff in there - unless I should look behind the glove box?
Postby sergei » Fri Jun 25, 2010 10:44 am
If it is anything like L series diesel, then it is under AC pump on the drivers side under the drivers seat. Alternator I mean.
I am not sure where is regulator, as I have never dealt with old stuff.
Postby cat007 » Fri Jun 25, 2010 10:49 am
sergei wrote:If it is anything like L series diesel, then it is under AC pump on the drivers side under the drivers seat. Alternator I mean.
Oh, no I know where the alternator is :roll:
I just cant find the regulator. Unless toyodiy's picture is wrong and it's internal to the alt?
Postby sergei » Fri Jun 25, 2010 11:02 am
I am fairly certain that this type of alternator is with internal regulator, while if you click >> you will see old type with external regulator.
Postby cat007 » Fri Jun 25, 2010 11:06 am
Oops - didn't mean to do the eye roll lol
I'll take the alternator off in the morning and see if I can get a better look at it.
Postby matt dunn » Fri Jun 25, 2010 9:54 pm
matt dunn wrote:probably behind the glove box.
In the old 4y toyota vans they are usually external reg and the reg is usually in behind the glove box, or at the base of the steering column which is a bitch to get to.
