Caldina GTT Dyno - Comment
Postby QikStarlie » Sun May 02, 2010 6:06 pm
or its just following boost spike
QikStarlie
Postby strx7 » Sun May 02, 2010 6:51 pm
the drop between 4 and 5 is there without a boost spike before it
Postby QikStarlie » Sun May 02, 2010 7:04 pm
ah yeh, do those versions run acis? (im not a 3s guy) would explain it,
acis manifold on e series does the same thing. not really that it causes a dip, just that they make more power down low and up high over a normal inlet. they go a bit flat before the switch over point
QikStarlie
Postby ®usty » Sun May 02, 2010 8:51 pm
^ nah thats just the 2nd and 3rd gen 3s-GE's that carry that intake system
®usty
Postby strx7 » Sun May 02, 2010 9:30 pm
Even custom intake manifold doesn't change it, hence i believe it is a head flow thing.
Postby Al » Sun May 02, 2010 9:30 pm
fivebob wrote:
Jingle Balls wrote:best dyno is quarter mile trap speed vs weight.
That would be the worst method for accurate comparision of HP, there are too may variables like tyres, track condition, driver ability etc etc etc.
I would disagree to some extent. Any muppet can make a reasonably clean start and just hammer the power down. As long as you don't miss any gears your trap speed should be very similar.
I have run 14 second 1/4s with 110mph trap speed. Along with 12 second 1/4s with 110mph trap speed. Your tyres and track conditions mean sweet fanny adams once you are rolling.
Al
Postby MAGN1T » Sun May 02, 2010 10:17 pm
That big spike half way through....that's what you can sometimes get with detonation, the ECU pulls the timing back and it starts climbing again. A bit less timing will probably fix it or a bit more octane.
They're supposed to run on 100RON?
The boost spike would have caused a bit of knock.Overall numbers maybe down due to timing pull.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Jingle Balls » Sun May 02, 2010 11:10 pm
exactly what i'm talking about, have done it myself too. it's physics. it takes X amount of power to propel X amount of weight to X speed within the fixed distance. all of the variables that i've seen mentioned will effect ET and any effect on trap speed will be within a much closer tolerance than the difference that i've seen some dynos produce.
there are many calculators on the net that will work around this same principle. here's a mathematical formula for the calculation
Net HP = Weight in pounds* (Speed in MPH/228.4)^3
Jingle Balls
Postby Lac » Thu Jun 03, 2010 11:52 pm
So i just got the car re - tuned and it came up as 150kw atw.
My mechanic ended up putting a wastegate restrictor on (not sure exactly what he did), he said it was due to the valve not opening up quick enough on the wastegate, causing to spike.
Caldina GTT Sydney
Lac
Postby QikStarlie » Fri Jun 04, 2010 6:30 pm
QikStarlie wrote:or its just following boost spike
hello
QikStarlie
Re: Caldina GTT Dyno - Comment
Postby BZG Wagon » Sun Jun 06, 2010 1:16 pm
Lac wrote:K&N panel filter
Where did you get this from?
I was told there aren't any made / that fit GTT's?
BZG Wagon
Postby Lac » Mon Jun 07, 2010 4:24 pm
I bought it on ebay - sent from NZ. I think its part number 33 - 2052 which fits heaps of cars.
Caldina GTT Sydney
Lac
