(3) Batteries:
(a) All batteries shall be securely mounted and have the live terminal adequately covered,
(b) Batteries located in the cockpit shall;
(i) Be mounted on a flat metal base, and
(ii) Have two insulated metal clamps affixed by a minimum of 8 mm (ISO 8.bolts and
nuts in combination with under floor counter plates, and
(iii) For ‘wet cell’ batteries an independently attached leak-proof box vented to the vehicle
exterior is required.
(iv) For a sealed “dry cell” (i.e.: may be fitted in any orientation, without any loss of fluid)
may be mounted in the cockpit without a leak proof box.
Mr Revhead wrote:i would double check with a scrutineer, but as long as you are not using tinfoul you should be sweet.
frost wrote:can people post pictures of there setup,
im putting the plastic batt box in boot now and the sealed and vented to outside part is quit strange, didn't know it needed to be vented,
if its that much stress i might just buy a dry cell,
matt dunn wrote:Mr Revhead wrote:i would double check with a scrutineer, but as long as you are not using tinfoul you should be sweet.
No wont get through all all that is holding it is PK screws and the material strap.
Need to bolt it down inside the box.
and not in your case, but if the box is inside the cabin,
you also need to seal the box which is a PITA.
matt dunn wrote:If it is in the boot, and the boot is sealed from the cabin, (i'e 4dr sedan)
then the box does not need to be sealed.
But if the boot is unsealed,( i.e. FXGT or 3dr Hatch)
then the box must be sealed and vented.
Stott69 wrote:Ive also made up a markI rubber cover for the positive terminal, surely the negative one wont need one
gurutasker wrote:The ventilation is a requirement, as it is a sealed box it needs to be able to breathe in case of a spill or any other leak.
RomanV wrote:Just to clarify though, this is a requirement for racing, but not for a WOF or cert. (Which I've heard some people say it is, in the past)
