Battery mounting
Battery mounting
Postby Stott69 » Fri Jun 04, 2010 8:23 pm
Been searching for the last hour, Can I be pointed toward the specs for the straps etc?
Image jzs147 Aristo money pit
Stott69
Postby Mr Revhead » Fri Jun 04, 2010 8:24 pm
Specs in regaurds to what? WOF? Racing?
Postby Stott69 » Fri Jun 04, 2010 8:32 pm
Raceing
Stott69
Postby Mr Revhead » Fri Jun 04, 2010 8:42 pm
Postby Flannelman » Fri Jun 04, 2010 8:49 pm
Dammit!
Just about to post the same thing!
Its a good website to have handy somewhere, could it be stickied under trackdays?
Or am I being slow and its already there...
Flannelman
formerly known as Affroman
Postby Stott69 » Fri Jun 04, 2010 8:57 pm
(3) Batteries:
(a) All batteries shall be securely mounted and have the live terminal adequately covered,
(b) Batteries located in the cockpit shall;
(i) Be mounted on a flat metal base, and
(ii) Have two insulated metal clamps affixed by a minimum of 8 mm (ISO 8.8) bolts and
nuts in combination with under floor counter plates, and
(iii) For ‘wet cell’ batteries an independently attached leak-proof box vented to the vehicle
exterior is required.
(iv) For a sealed “dry cell” (i.e.: may be fitted in any orientation, without any loss of fluid)
may be mounted in the cockpit without a leak proof box.
nothing about the thickness or anything of the straps?
Stott69
Postby Mr Revhead » Fri Jun 04, 2010 9:02 pm
Where is your battery?
Postby Stott69 » Fri Jun 04, 2010 9:06 pm
Box in the boot of the trueno but not bolted down yet, just straped and pk screwed to the interior
Stott69
Postby Mr Revhead » Fri Jun 04, 2010 10:28 pm
i would double check with a scrutineer, but as long as you are not using tinfoul you should be sweet.
Postby matt dunn » Fri Jun 04, 2010 11:25 pm
Mr Revhead wrote:i would double check with a scrutineer, but as long as you are not using tinfoul you should be sweet.
No wont get through all all that is holding it is PK screws and the material strap.
Need to bolt it down inside the box.
and not in your case, but if the box is inside the cabin,
you also need to seal the box which is a PITA.
Postby frost » Sat Jun 05, 2010 12:36 am
can people post pictures of there setup,
im putting the plastic batt box in boot now and the sealed and vented to outside part is quit strange, didn't know it needed to be vented,
if its that much stress i might just buy a dry cell,
Postby matt dunn » Sat Jun 05, 2010 12:47 am
frost wrote:can people post pictures of there setup,
If it is in the boot, and the boot is sealed from the cabin, (i'e 4dr sedan)
then the box does not need to be sealed.
But if the boot is unsealed,( i.e. FXGT or 3dr Hatch)
then the box must be sealed and vented.
Basically they have decided that you must not be able to inhale the battery vapours, but the vapour must have somewhere to go.
Postby Mr Revhead » Sat Jun 05, 2010 1:19 am
I was not reffering to his pk screws :lol:
Postby Stott69 » Sat Jun 05, 2010 7:04 pm
Think Ive sorted it now, will post up pics on what Ive done later in the weekend
Stott69
Postby Stott69 » Sun Jun 06, 2010 6:26 pm
Some of the pics of what Ive done, am I taking the right approach?
Welded in brackets for the battery to sit on and rods to bolt to, 2mm steel
What Im useing for the clamp
Battery in place with m10 rod for clamping
Stott69
Postby gurutasker » Sun Jun 06, 2010 6:36 pm
matt dunn wrote:If it is in the boot, and the boot is sealed from the cabin, (i'e 4dr sedan)
Note: not all 4-dr sedans have a sealed boot.
Taking a quick look at the photos have you got:
"with under floor counter plates".
These can be as simple as some large flat washers.
there is no specification listed AFAIK for the size of the straps, however because you are using steel, you will need to find a way to insulate it. (I've got plastic tube over mine, if you end up coming over tomorrow you will see).
The ventilation is a requirement, as it is a sealed box it needs to be able to breathe in case of a spill or any other leak.
:twisted: Wellington's TS Midget :twisted:
gurutasker
Postby Stott69 » Sun Jun 06, 2010 6:47 pm
Ive also made up a markI rubber cover for the positive terminal, surely the negative one wont need one
Stott69
Postby gurutasker » Sun Jun 06, 2010 6:48 pm
Stott69 wrote:Ive also made up a markI rubber cover for the positive terminal, surely the negative one wont need one
Correct.
gurutasker
Postby RomanV » Sun Jun 06, 2010 7:20 pm
gurutasker wrote:The ventilation is a requirement, as it is a sealed box it needs to be able to breathe in case of a spill or any other leak.
Just to clarify though, this is a requirement for racing, but not for a WOF or cert. (Which I've heard some people say it is, in the past)
Postby gurutasker » Sun Jun 06, 2010 7:28 pm
RomanV wrote:Just to clarify though, this is a requirement for racing, but not for a WOF or cert. (Which I've heard some people say it is, in the past)
I'm only giving guidance for MSNZ Schedule A requirements.
gurutasker
