I have an 1991 AE92 GT-i, with presumably the smallport motor (red/black writing on cam cover)
Its done 280,000km and due to a leaky sump gasket is has been slowly losing oil.
i now have some funds to fix it - the oil in the car is about 1/3 full i would say by the dip stick.
I have been noticing vary odd faint sounds from the engine, but it has a loudish exhaust so hard to tell, but I am probably just hearing things and presuming something bad.
The noise could be due to low oil?
Anyway, im giving it a full service oil, coolant, plugs, filters etc and am wondering what numbers, an engine of these km's would produce in a compression test. I have looked on the net and found 179/180 to be standard for a new engine? So obviously with the age would be lower.
Just wanting to get info to see whether it is worht spending money on a service now, or get a better block to replace it then spend money on that.
Any thoughts would be great.
Cheers, Jason
