h8wrxs wrote:im nto after full track suspension btw, just a street setup
Mr.Phreak wrote:h8wrxs wrote:im nto after full track suspension btw, just a street setup
Then get a set of decent shocks and springs
SM-Design wrote:Mr.Phreak wrote:h8wrxs wrote:im nto after full track suspension btw, just a street setup
This
Why are you spending all that on racing suspension?
Get some harder springs and nice shocks. Will drive nice and be better in the hills.
h8wrxs wrote:SM-Design wrote:Mr.Phreak wrote:h8wrxs wrote:im nto after full track suspension btw, just a street setup
This
yes you're right, this is exactly what started the argument with my mate
problem is i currently have a custom setups with koni shock/spring that was setup by the previous owner for gravel racing and it sits at about 190mm off the ground
i want to lower it to about 110mm or so but dont want to screw up the handling with a set of king springs
so how do i work out the correct spring/ shock setup to use and how do i workout what spring rate etc to use??
i dont know anything about suspension...
Mr Revhead wrote:
I would see about a set of TEIN's and some Koni shocks in a perfect world.
craigt wrote:KYB struts and Tein springs in my AE101. Superb combination and KYBs arent too pricey. Lowest part under the vehicle is the front swaybar mounts at 105mm from ground, thats low for an AE101
sergei wrote:craigt wrote:KYB struts and Tein springs in my AE101. Superb combination and KYBs arent too pricey. Lowest part under the vehicle is the front swaybar mounts at 105mm from ground, thats low for an AE101
BTW Toyota genuine struts are very likely to be KYB or Tokico.
Mr Revhead wrote:sergei wrote:craigt wrote:KYB struts and Tein springs in my AE101. Superb combination and KYBs arent too pricey. Lowest part under the vehicle is the front swaybar mounts at 105mm from ground, thats low for an AE101
Yes but very different from the KYB's you buy off the shelf over here
