Snapped wheel stud
Snapped wheel stud
Postby celica_xr9145 » Mon Jun 14, 2010 5:46 pm
Went to put the wheel back on and whilst tightning the last nut, the stud snapped off.
Whats involved in replacing it?
From what i've read the old one comes out and can replace it with a new stud, is that right? If so how does it come out?
Also, where would one go about getting 1 wheel stud?
Thanks
www.Garage-X.org - Car Awesomeness
Facebook.com/garagexnz - Now on FB!!
95' Zenki Silvia S14, 99' BMW 328i E46
celica_xr9145
Postby tsoob » Mon Jun 14, 2010 5:51 pm
get them from partmaster or toyota.
you just take the wheel and the brake disc off
bash the old one out put the new one thru then put a large thick washer over it and use the nut to rattle it thru with your gun.
take the washer off and put it all back together
with the right tools its a 5 min job.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby thegreatestben » Mon Jun 14, 2010 5:52 pm
Smack it out with a hammer.
Buy a new one from any place that sell car parts. Repco, supercheap etc etc
thegreatestben
Postby celica_xr9145 » Mon Jun 14, 2010 5:54 pm
Thanks for the quick replies, didn't think supercheap or repco would sell them, am i right in saying that it has to be specifically for toyota and specifically for a AE111 Toyota (has superstrut if that matters)?
Looks like i will have to go there during morning smoko, what sort of price do you think i will be paying for a stud? Would go there now but its shut :?
Thanks again
celica_xr9145
Postby eskimo » Mon Jun 14, 2010 6:12 pm
Wheel studs are cheap as its an easy job. Part Master BNT or TGP would be your best bet.
From memory SCA/Ripco only have trailer ones avalible off the the shelf.... I could be wrong thoe
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby 79rolla » Mon Jun 14, 2010 6:22 pm
all you need is a new one of the same size and thread nothing speachail about them generally
past: AE82 FXGT
79rolla
Postby MR2BOY23 » Mon Jun 14, 2010 6:22 pm
Supercheap don't stock them, can get them from Autostop if you have those down there
MR2BOY23
Postby pc » Mon Jun 14, 2010 6:37 pm
Some front wheel studs can't be replaced with the bearing intact... might want to check that there is room to get the new stud in without taking the bearing apart.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby z0ton » Mon Jun 14, 2010 7:07 pm
At Repco the partnumber should be ZNS340 I think...
z0ton
Postby celica_xr9145 » Mon Jun 14, 2010 8:42 pm
will go to repco and BNT tomorrow so will see, want to get it done soon as because im currently driving on 3 wheel nuts :?
celica_xr9145
Postby sergei » Mon Jun 14, 2010 10:26 pm
celica_xr9145 wrote:im currently driving on 3 wheel nuts :?
Don't do that. You are going to kill some one.
If I were you I would replace whole lot. They are about $5 each. If one snapped there should be a reason why. Over-tightening is most common cause. At least you need to inspect all other ones for cracks and stretching in same place where the first one snapped.
And don't drive it with 3 wheel nuts.
Postby fangsport » Mon Jun 14, 2010 10:40 pm
seconded. they are as cheap as chips to buy. TWL or any good engineering shop should be cheaper than repco or bnt, as you should be able to buy them without the frilly packaging.
fangsport
Postby h8wrxs » Tue Jun 15, 2010 9:50 pm
you might be best off to take one of the others out and take it to repco with you, i had this problem a few months ago and they had all the studs in a box mixed up, not labelled or anything.... and they arent always a 5 min job, i had ALOT of trouble getting the old studs out...
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby fangsport » Tue Jun 15, 2010 9:59 pm
h8wrxs wrote:you might be best off to take one of the others out and take it to repco with you, i had this problem a few months ago and they had all the studs in a box mixed up, not labelled or anything.... and they arent always a 5 min job, i had ALOT of trouble getting the old studs out...
geez, your local Repco must be average, all the ones i have been into, have them on a revolving rack in blister packs, hence the reason why one should go to a engineer type supplier, so one dosn't pay for packaging.
fangsport
Postby Malcolm » Tue Jun 15, 2010 10:31 pm
h8wrxs wrote: and they arent always a 5 min job, i had ALOT of trouble getting the old studs out...
sounds like you need to invest in a bigger hammer.
Postby celica_xr9145 » Tue Jun 15, 2010 10:45 pm
Repco didnt have the studs so ended up going to Toyota. Have the day off work tomorrow to fix the car.
Is it really necessary to take off the hub? I've seen a lot of tutorials on removing studs with the hub left on with big american cars with loads of clearance but haven't had time to check how much clearance i have.
Last edited by celica_xr9145 on Tue Jun 15, 2010 11:38 pm, edited 1 time in total.
celica_xr9145
Postby Dell'Orto » Tue Jun 15, 2010 11:30 pm
No, PS pump isnt run off a cogged belt. Either your pump is knackered, or your tyres are underinflated.
Postby celica_xr9145 » Tue Jun 15, 2010 11:37 pm
Dell'Orto wrote:No, PS pump isnt run off a cogged belt. Either your pump is knackered, or your tyres are underinflated.
But isnt it possible for the belt to slip?
Just noticed i posted in the wrong thread :oops:
celica_xr9145
Postby Malcolm » Wed Jun 16, 2010 12:13 am
celica_xr9145 wrote:Repco didnt have the studs so ended up going to Toyota. Have the day off work tomorrow to fix the car.
you shouldn't have to take off the hub, there is usually clearance and a gap in the brake dust shield for changing studs.
Postby h8wrxs » Wed Jun 16, 2010 3:26 am
Malcolm wrote:sounds like you need to invest in a bigger hammer.
i ended up doing exactly that.... i seriously thought i was going to do more damage than good in doing so thought haha
h8wrxs
