Engine temperature gauge drops very low when over 80kph
Postby -MATT- » Thu Jun 17, 2010 5:35 pm
Hi guys, I've just fitted an APEXi pod filter to my AE101 Marino 20v and took it for a drive out Maraetai and I noticed that at speeds above 80kph the engine temperature gauge would drop drastically down to the very bottom. Then when going back to 50kph it would go back to normal.
I have retained the AFM as the POD came with the attachment. Any ideas what might be causing this? Thermostat stuck open?
Cheers,
Matt
-MATT-
Re: Engine temperature gauge drops very low when over 80kph
Postby sergei » Thu Jun 17, 2010 5:54 pm
-MATT- wrote:Hi guys, I've just fitted an APEXi pod filter to my AE101 Marino 20v and took it for a drive out Maraetai and I noticed that at speeds above 80kph the engine temperature gauge would drop drastically down to the very bottom. Then when going back to 50kph it would go back to normal.
Cheers,
Matt
Yes, thermostat stuck open.
Postby maddog » Thu Jun 17, 2010 7:13 pm
+1
-- 1992 AE101 Corolla FX-GT --
maddog
Postby strx7 » Thu Jun 17, 2010 8:40 pm
maddog wrote:+1
+2
Postby eskimo » Thu Jun 17, 2010 8:45 pm
+3 :D
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby frost » Thu Jun 17, 2010 9:14 pm
i too will jump onto the bandwagon +4
Postby -MATT- » Thu Jun 17, 2010 9:42 pm
Kool thanks all :D Will get it sorted
-MATT-
