Hey,
just wondering how much, roughly it would cost to get a clutch replaced in a 96' BZG??
Thanks in advanced!
Tim
levinguy wrote:i think the tgp clutch kit is 199 plus (trade), so try and find someone who can get that price.
3-400 for it, even genuine, is just crazy for a 4age.
try mark the toyota forum sponser![]()
then you'd just be looking at labour plus flywheel skim, its a fairly simple clutch to change.
BZG|Bling wrote:Add your location to your profile on here.
I'm assuming you are in chch, give Graham a ring, he's a good sort, would trust him with my car any day.
http://yellow.co.nz/companies/Automotiv ... 7_880.html
watchthisspace wrote:Thanks, Graham seems like a very friendly guy and quoted me one of the cheapest prices of getting the clutch replaced with a standard one.
rollaholic wrote:the master cylinder is the hydraulic bit that the clutch lever actuates when you push it in, this transfers pressure to the slave cylinder which is bolted to the gearbox on your car, and pushes the clutch rod into the clutch fork, which dis-engages the clutch. both have seals which wear, which is why allencr was talking about replacing them.
