emission line off fuel tank
Postby bluemaumau » Sun Jun 20, 2010 3:02 pm
so in the midst of putting my fuel lines in my car (ae101) and was wondering if i could remove some of the hard lines as they are in the way.
i know there are 5 lines running to the rear.
2 brakes
3 fuel
obviously one is return and one the feed, so i assume the other is emissions. i remember seeing it when the tank was out.
so whats the deal?
can i remove it and plug it at the tank? or does it need to breathe?
running external fuel pump and surge tank if it makes any difference
thanks
Postby Rick » Sun Jun 20, 2010 4:26 pm
That line is the breather line which you need, a breather but not necessarily the line running the full length of your car, it will go to a charcoal canister on the passangers side of your engine bay. Its for emissions. I removed the factory breather line and canister and ran a small rubber line to the back bumper area where a put a breather.
Postby bluemaumau » Sun Jun 20, 2010 8:11 pm
cheers rick. might just do the same
Postby Bazda » Mon Jun 21, 2010 1:01 pm
I would also install a 1 way vent valve onto that as well.
Incase you roll the car or something crazy fuel wont pour out.
Postby bluemaumau » Mon Jun 21, 2010 7:36 pm
good idea. any suggestions on where to get these items?
Postby Rick » Mon Jun 21, 2010 8:02 pm
I was going to post up a link from tradme, there was a guy selling them for quad bikes, it allowed the tank to breath but didn't let any fuel spill out it appears he isn't selling them anymore.
