GDII wrote:Why haven't you got Laas onto this? Or has he refused to help you with your cars anymore?
dnalunchie wrote:Before i got a chance to replace the BHG last time the engine did get pretty hot a few times so maybe the block has gone soft and wont seal properly?
whynot wrote:If I remember right you will need to mess round with the cam belt tensioner to replace the water pump on these motors. If you have the tools and know how to change a cam belt then this will seem pretty straight foward.
strx7 wrote:
i'd reccomend talking nicely to me, and putting a G13B into the cooling system, it should be good for another 120km/h + grin factor
dnalunchie wrote:Is this just sumthing I can go at with a box of tools?
I believe I have to take the belt off but Is there anything I have to be wary of? Should I disconnect the batter for instance?
allencr wrote:dnalunchie wrote:Is this just sumthing I can go at with a box of tools?
No, if you have to ask, you can't, and considering the other questions asked, I'm pretty sure you can't.
Can you afford to learn the hard way, if not then don't?
MAGN1T wrote:Murphy's law says that the last headgasket job done on the car wasn't done properly.
Needs doing again.
Too much pressure blows the coolant our through the seal.
Steve
MAGN1T's Law wrote:BHG
