3SGTE JE Forged Piston Rings - Help
Postby Heylin » Tue Jun 22, 2010 5:06 pm
Only ring set I can find for 3SGTE 86.5mm bore on JE Site is JG1004-3405 so assuming this is the right one ?
But the place im buying from wants me to measure ring thickness as they say there are possibly (they couldnt be sure) 2 sets of rings available. I think they may be getting confused by looking at individual rings for 86.5mm bore and not the engine application.
Indeed if you look at 86.5mm bore individual rings it comes up with 2 entries for each ring type, the first set matching those in the 3sgte ring set above
Top 1.0mm Carbon Steel \ Nitrate, Bar BCut
Second 1.2mm Ductile Iron \ Phosphate, Napr BCut
Oil 2.8mm Carbon Steel \ Nitrate, flexivent
Top 1.5mm Ductile Iron \ Chrome, Bar DWall
Second 1.5mm Iron \ Phosphate, tapered wall, file to fit 0.005in
Oil 4.0mm Carbon Steel \ Chrome, flexivent
So whats the deal with the second set made from different material and coating and slightly thicker ?
Heylin
Heylin
Re: 3SGTE JE Forged Piston Rings - Help
Postby allencr » Wed Jun 23, 2010 4:29 am
Different whims/preferences.
Just get the thickness right!!!!!!!!!!
allencr
Postby Heylin » Wed Jun 23, 2010 3:46 pm
Picked up some rings from a TS member (big thanks).
Chrome Carbon Steel ones
Seems my ring size was slightly different to the current 3sgte JE pistons which are 1.0 x 1.2 X 2.8
mine are 1.2 x 1.5 x 4.0, possibly they changed their piston design for 3SGTE or ive got the universal 86.5mm sport compact pistons.
Heylin
Heylin
Postby MilfHunter » Fri Jun 25, 2010 7:37 am
The thinner ringed version is a race version, intented to be changed regulary
The thicker ringed pistons are the street version.
There's very little power advantage and won't last anywhere near as long as the thicker versions
MilfHunter
