Strange water Leak (Urgent help toyspade)
Postby dnalunchie » Wed Jun 23, 2010 7:31 pm
Headgasket was fine.
Water pump was fcuked
Replaced
Now all spiffy
EX:89 RS and GT Legacys, 90 EF9 Civic, 95 Integra R, 95 AE101, 90 ST185, 88 Accord, 87 3rdoor and 5door Swift hatch, 91 Pontiac Lemans, 80 Liftback Celica, 95 Hornet 250
Current: 90 3sfe Corona
dnalunchie
Postby Burning Angel » Wed Jun 23, 2010 7:40 pm
MAGN1T wrote:Murphy's law says that the last headgasket job done on the car wasn't done properly.
Needs doing again.
Too much pressure blows the coolant our through the seal.
Steve
are u saying i don't know how to change a headgasket?
and even if that were true the cooling system could only be pressurized as much as the radiator cap will allow(15psi or so) therefore could not blow the seals on the pump, which aren't even rubber.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby dnalunchie » Wed Jun 23, 2010 7:45 pm
Needs doing again.
Steve
Yeah thats what he is saying. He thinks that you shouldnt have just used sealant instead of using a genuine gasket
dnalunchie
Postby Malcolm » Wed Jun 23, 2010 9:58 pm
...can't blow the headgasket if you don't have one!
