sergei wrote:cat007 wrote:Thank you for that. Where would that be located do you think?
By looking at pic, it should be on the alternator, on a side, close to back side, since there are brushes sticking out of the thing.
MR2BOY23 wrote:Yeah they can order them in for you
sark.inc wrote:Dell'Orto wrote:Could have tried an Appco branch, they stock auto electrical bits.
generally if appco have it, repco can just get it off them, or send you down to them.
sergei wrote:If it is anything like L series diesel, then it is under AC pump on the drivers side under the drivers seat. Alternator I mean.
I am not sure where is regulator, as I have never dealt with old stuff.
cat007 wrote:sergei wrote:If it is anything like L series diesel, then it is under AC pump on the drivers side under the drivers seat. Alternator I mean.
Oh, no I know where the alternator is![]()
I just cant find the regulator. Unless toyodiy's picture is wrong and it's internal to the alt?
sergei wrote:
I am fairly certain that this type of alternator is with internal regulator, while if you click >> you will see old type with external regulator.
matt dunn wrote:probably behind the glove box.
