4a sump > 7a block
4a sump > 7a block
Postby NOLAW » Mon Jun 28, 2010 11:28 pm
Pretty straight forward question, Am i able to use my 4agze sump on a 7a block?
NOLAW
Postby gasman » Tue Jun 29, 2010 10:35 am
arent some 7a blocks a 2 piece sump?
"What can possibly go wrong?"
gasman
Postby thegreatestben » Tue Jun 29, 2010 1:12 pm
mine is.
Alloy section with a steel pan
thegreatestben
Postby NOLAW » Tue Jun 29, 2010 5:03 pm
yeah i think thats what mine looks like too, so i cant use my 4agze sump? as im worried my sump is now going to hit the swaybar, is it bad practice to notch th sump out for the swaybar or is this a harder practice than it sounds?
NOLAW
aye
Postby ezy10s » Wed Jun 30, 2010 9:00 pm
what vehicle you wanting to put it in?
Member #244
Gone fishing until further notice
ezy10s
Postby NOLAW » Wed Jun 30, 2010 10:48 pm
its going into a 1973 corolla (KE20)
NOLAW
hmm
Postby ezy10s » Thu Jul 01, 2010 7:27 am
if youve using the mounts that grotty makes to sit a 4age in ke20 then the 7a will clear also. if not- no idea sorry
Member #244
ezy10s
Postby AceSniper » Thu Jul 01, 2010 9:53 pm
20v sump will fit, you will need to use the 20v pickup also
depends if the gze sump is the 20v shape or the older 16v shape
AceSniper
