tial wastegate not shutting properly??
Postby d1 mule » Wed Jun 30, 2010 11:18 pm
hey,
so after FINALLY taking my car for its maiden thrash at the track after rebuilding it, I decided to remove the boost controller and just put the appropriate spring rate springs in the wastegate, as i noticed some weird things happening on the gauge. (was peaking then dropping back to spring press (10psi) rather than boost controller press (14psi))
so after much pissing about i got the wastegate off (which is a Tial 38mm V band new type one) I noticed on the exhaust side the piston type thing doesnt seat perfectly on the housing, which i would assune would be essentially a permant exhaust leak???
is this normal????
d1 mule
Postby matt dunn » Wed Jun 30, 2010 11:35 pm
All the ones ive seen including my Tial one,
have a removable seat that the gate seals on,
and it falls out easily every time you pull it off.
Your pictures are not that great, but it looks like the actual seat is missing?
edit: not a genuine one but this picture shows the seat in the back at the top.
http://www.trademe.co.nz/Trade-Me-Motor ... 461179.htm
Postby cat007 » Wed Jun 30, 2010 11:51 pm
matt dunn wrote:All the ones ive seen including my Tial one,
Yeah there's supposed to be a seat there....
Postby d1 mule » Wed Jun 30, 2010 11:59 pm
iv had a look around and there is nothing on the ground that looks like it could have been in there.
this seat, is it supposed to go inbetween the valve (moving part) and the housing, because if it is i dont see how it would fall out
ad i dont see a seat thing in this diagram
http://www.tialmedia.com/Exploded/MVSexploded.jpg
d1 mule
Postby CAMB01 » Thu Jul 01, 2010 12:10 am
The seat is there in your pictures.
When you fit the wastegate at least with the 2 bolt style ones, the seat gets pushed in up against the valve and seals it. Not sure how it works with the clamp type, im assuming the same way.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby d1 mule » Thu Jul 01, 2010 12:29 am
crisis overted, thanks CAMB01, gave the seat i tap with harry the hammer and all was sorted.
thanks heaps guys
d1 mule
Postby strx7 » Thu Jul 01, 2010 8:14 am
is it an actual tial wastegate or a tial style one?
Postby d1 mule » Thu Jul 01, 2010 7:05 pm
actual tial 38mm MV-S, new style V band
d1 mule
