Mr Revhead wrote:500+ round town in a slushomatic Caldina turbo?
Good luck with that!
All sounds about normal to me
stevedabomb wrote:96 but will try bp 98 on the next tank to see if it makes any difference
stevedabomb wrote:woops 95 lol not sure why they went down from 96 to 95 - i just assumed for daily driving arround town with not much use of turbo that 95 would be ok and obviously cheaper $90 a tank
Crampy wrote:Give the car a good service, plugs filters oil change etc.
Make sure the tyres are pumped up good, I do mine at 38ish psi.
Also make sure the car is heating up quickly. A cold car will always run REALLY rich. Don't heat a car up by idling it on the driveway, just drive it, it's better for it and it'll heat up quicker.
GT101 wrote:Crampy wrote:Give the car a good service, plugs filters oil change etc.
why is it better to warm up your when driving instead of sitting in one spot?
It's heats up faster (and more evenly I suppose???) and loads the motor as opposed to just idling it, which is bad for an engine.
stevedabomb wrote:Just wondering if anyone has any tips as to why it may be using more gas than it should - havent changed spark plugs so will give that a go first i guess
