225 45 17 to wide for ae111?
Postby gleem » Sun Jul 04, 2010 11:16 am
just got a set. currently have 215 40s on there with no real ploblems. Just want to know if anyones tried this before i pay to get them put on etc thanks
gleem
Postby Dell'Orto » Sun Jul 04, 2010 11:51 am
Depends on how low it is. Fairly big sidewall compared to a 215/40
Postby Bling » Sun Jul 04, 2010 1:32 pm
Why would you? :? Doing some off roading are we?
I assume they are subaru sized tyres and you are getting them for cheap of something :?: Can't see any other reason than $$$ to go with a tyre so different to factory sized.
Postby gleem » Sun Jul 04, 2010 2:14 pm
yeah i got them cheap as. I didnt realise 225 45 17 was that much bigger
gleem
Postby Bling » Sun Jul 04, 2010 2:15 pm
Just don't sit at 100km/h on your speedo as you will be fined :wink:
Postby Boosted_162 » Sun Jul 04, 2010 2:22 pm
There is a 5.1" difference in rolling circumference over the 215/40/17.
Postby Bling » Sun Jul 04, 2010 2:24 pm
Pretty sure 205/40 17 is the same size as factory though. Which means 6.5% (a site told me that so could be wrong)
Postby Boosted_162 » Sun Jul 04, 2010 2:29 pm
BZG|Bling wrote:Pretty sure 205/40 17 is the same size as factory though. Which means 6.5% (a site told me that so could be wrong)
Yeah that is correct. I wasnt sure on AE111 standard tyres so couldnt compare :P
It means that at 100k's you are doing 106.
Postby gleem » Sun Jul 04, 2010 3:33 pm
so the problem is the 45 profile not the 225 width
gleem
Postby Bling » Sun Jul 04, 2010 4:09 pm
Combo of both. 45% of 225 is more than 40% of 205.
Either way check what clearance you have now from the struts as mine comes pretty close of 205s. 225s may rub on the strut / inner guards on full lock.
Over the 205/40 for example, you have gone to a bigger diameter and a wider width, so you're just increasing the chances of getting rubbing. That's ignoring any handling difference having the wider tyres may or may not having on the car.
We'll ignore the fact that if a WOF inspector was picky you could fail for using tyres greater than 5% bigger than factory. :wink:
Postby gleem » Sun Jul 04, 2010 5:15 pm
while on the topic, i cant find online whats the differences between pirelli tyres. pzero neros, p600 and p7?
gleem
Postby Bling » Sun Jul 04, 2010 6:08 pm
Postby tsoob » Mon Jul 05, 2010 2:34 pm
yep wrong tyres mate!
215 40 17 would be the absolute biggest..
if its lowered you may have issues with rubbing, can do you a really sweet deal on toyo tyres if you like?
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby BigDon » Mon Jul 05, 2010 11:12 pm
Ive run 215/40/17s on mine in the past, they just fit.
With that profile and width dependent on your offset you might get rub on the strut or spring perch as well as guard rub, the bottom of the perch can be "massaged" up slightly with a hammer, but if your hitting the strut your knackered. All and all not good.
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
