iOnic wrote:Use a tube. Impossible to tell whether you still have air in the system without one and it can also suck air back into the system if you don't have a tube submerged in fluid and sealed against the nipple properly.
Also put some effort into making a proper brake bleeder bottle. A good brake bleeder bottle and a good seal between bleed nipple and tube will save a lot of lost fluid and make the job quicker/cheaper.
Bunnings sells some clear hose for a coupla $ per meter (a meter is plenty). The rest is the same as any other car with the master cyl on the driver's side. RR, RL, FL, FR and don't let the resevoir go empty at any point.
sergei wrote:When I bleed brakes I use pressure method:
I tell "brake presser" to pump couple of times and press hard and hold the brake.
Then I untightened the bleed screw until the liquid stops comping out (when the pedal went down completely).
I tighten while the "brake presser" still holds the brake pedal pressed.
I tell "brake presser" to release and pump couple of times and press and hold again and repeat.
What you need to do is start from the further point in the system and progress to the closest (Left Rear, Right Rear, Left Front, Right Front).
This method is tedious, but it also good to make sure you don't suck air back in.
blindnz wrote:sergei wrote:When I bleed brakes I use pressure method:
same method i use. probably should get a hose and things though.
snwtoy wrote:I had to lookup Cytherea
sergei wrote:Don't lookup Cytherea if you are in Australia.
It will make you a pervert and paedophile.
As big brother of govt would love to jail you for small boobs and squirting.
http://www.smh.com.au/opinion/society-a ... -n278.html
http://www.sexparty.org.au/index.php/pr ... tion-board
cogent wrote:iPhones can eat a dick.
Dell'Orto wrote:Used one of those one man bleeders and had a heap of issue though
tsoob wrote:we have a little hose with a one way valve on it, you just get it on and pump away, no need to open and close the nipple. you can even do it on you own!!
sergei wrote:tsoob wrote:we have a little hose with a one way valve on it, you just get it on and pump away, no need to open and close the nipple. you can even do it on you own!!
Well 1 problem with that system - thread. if the hose goes on nipple there is a possibility to suck through the thread of the nipple since it needs to be loose to allow liquid through.
