Quint wrote:atm, guards are 6" above the wheel, rivals the hilux for clearance :p
Mr Revhead wrote:Quint wrote:atm, guards are 6" above the wheel, rivals the hilux for clearance :p
stop using space savers?![]()
If you really do need to drop it 6"s () then the only way is going to be a serious set up as that much of a drop will alter your geometry massively!
Mr Revhead wrote:Dobis are fine for road cars, if fitted to the right application!
Quint wrote:Sweet, time to pull out the shocks for a 3rd time. God dammit.
Cheers lads.
Mr Revhead wrote:they were cheap as cheap can be through toyota
cat007 wrote:What shocks are you using? if you can, grab a set of bilsteins from the JZA70 R type supra...
