ae101 rolla issues help ????
Postby ae101_rolla » Sat Jul 03, 2010 4:06 pm
Ive just put my car back together after getting some things done and now when I drive it runs fine and then the rev counter flips out going all over the place the car starts missing and running like shit what could this be (ecu,timing,sparkplugs,leads) ???
ae101_rolla
Postby Rick » Sat Jul 03, 2010 4:19 pm
Have you had the motor out? or a lot of engine stuff removed? could be not very good earthing, check ingiters, coilpacks are earthed well, earth cable on block/gearbox tight etc..
Postby Dell'Orto » Sat Jul 03, 2010 4:27 pm
Dud earth somewhere, likely the negative battery terminal
Postby ae101_rolla » Sat Jul 03, 2010 5:15 pm
Thanks guys yea the motor has been replace at some stage am I best to make my own earth wire kit say 5 or 6 lenghts from the neg battery teninal to other parts
ae101_rolla
Postby KinLoud » Sat Jul 03, 2010 10:28 pm
I have a rev counter go crazy with occasional rough running...
Worked out it was a failing ignition lead
Postby ae101_rolla » Sat Jul 03, 2010 11:00 pm
Were do I find the Ignition lead ????
ae101_rolla
Postby metal_sean_head » Sat Jul 03, 2010 11:01 pm
ae101_rolla wrote:Were do I find the Ignition lead ????
8O 8O 8O
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby maddog » Sun Jul 04, 2010 9:17 am
:lol:
-- 1992 AE101 Corolla FX-GT --
maddog
Postby KinLoud » Sun Jul 04, 2010 11:24 am
ignition lead = sparkplug lead
I really hope you are joking about this!
Postby ae101_rolla » Tue Jul 06, 2010 4:14 pm
Tryed to start my car today and it fires up for 2 seconds and the dies It just wont go so I pulled the ecu out it looks fine and when I pulled number 1 lead off the rattles would this stop the car from running or is my ecu fired or is my timing completey screwed up
ae101_rolla
Postby tsoob » Tue Jul 06, 2010 5:22 pm
dude you need a mechanic or auto sparky.. you gonna cost your self more $$ if you keep messing with it
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
