.:O4AGTZ:. wrote:When you serviced them I would hope that you used a vice to push the piston back in. Also check the sliders as they tend to sieze.
sergei wrote:.:O4AGTZ:. wrote:When you serviced them I would hope that you used a vice to push the piston back in. Also check the sliders as they tend to sieze.
That is very wrong for rear.
If you use vice to push rear on a car with dual purpose calliper (ie brake+handbrake) you are going to stuff the thread in the self adjusting handbrake mechanism making the calliper seized.
It needs to be wound in. No hammer, no vice. There is even a "+" groove to put a large flat screwdriver (and to stop from winding when the pad is there - it will have notch that will go in the groove).
+1 On sliders.
