Name that diff
Name that diff
Postby Coldspark » Fri Jul 09, 2010 7:50 pm
from my celica xx
the last owner replace it, with something he doesn't know
Im assuming F series?
oh allso its not lsd
Coldspark
Postby deaf_rattle » Fri Jul 09, 2010 7:56 pm
assuming he hasnt done anything silly like replace it with a t series diff it should be an f series.
Unfortunately the best way to tell the ratio is by taking the backing plate off and doing a tooth count.
LSD will have lsd oil sticker on the right hand side fin, this doesnt come off very easily, but can be covered in years of crud.
Postby Coldspark » Fri Jul 09, 2010 8:18 pm
deaf_rattle wrote:assuming he hasnt done anything silly like replace it with a t series diff it should be an f series.
i called the guy before and he doesn't know, he just wanted something that he could blot in asap
and yes you would think it would be silly. but im allso not too sure what the extra holes were for or why they are there
Coldspark
Postby metal_sean_head » Fri Jul 09, 2010 8:21 pm
Um im going to call him steve.
So the previous owner just banged in any old diff that fit? LOL
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby Coldspark » Fri Jul 09, 2010 8:27 pm
i think he said he got it from christchurch if that helps LOL
edit: were would the number be stamped on it
Coldspark
Postby KinLoud » Fri Jul 09, 2010 8:51 pm
The subframe looks a lot one I modified.
The extra holes are so an F series diff will fit into a T series subframe (or vice versa).
Can't quite tell if it is a T or an F series diff. A better pic of the rear cover would be good.
Ken
Postby Coldspark » Fri Jul 09, 2010 9:03 pm
As requested
Coldspark
Postby Zestripper » Fri Jul 09, 2010 9:32 pm
That's a t series. Only 3 bolts on top and the backing plate is the same as a t series I have laying around here. Also being a 1g-eu usually means a t series rear end. What does the engine bay build plate say?
Zestripper
Postby Coldspark » Fri Jul 09, 2010 10:24 pm
TRANS / AXLE a42dl t282
i did check that first but though it could be wrong has he has replace it and hows it manual aswell
so if i say 1jz-ge and this diff = NO!!!
Coldspark
Postby Zestripper » Fri Jul 09, 2010 11:06 pm
It's likely the car has been converted to manual at some stage. Might have an interesting history to it? A lot can happen in the 25 years + since the car left the Toyota factory. Since your subframe is out of the car it's pretty easy to replace with a f series subframe and diff. Here's a couple of F series pics for reference anyway:
And yeah, 1jz + t series = not for long
Zestripper
Postby Coldspark » Sat Jul 10, 2010 12:00 am
The a42dl4 is a 4 speed auto so definite has been converted.
oh this has had a odd pass
cheers for the photos ill have to keep an eye on tm now
Coldspark
Postby Brawler » Sat Jul 10, 2010 12:19 pm
What gearbox do you have?
because I have a W50 that has had some kinda bellhousing mod done so it fits onto the 1G engine, as I don't think there are any bellhousings for the W50 for 1Gs. Mine was converted from auto and has a T series diff
zing! Sig got nuked. Sorry bout that.
Brawler
Postby rollaholic » Sat Jul 10, 2010 12:27 pm
i had a mark II with a 1ggze, w series box (55 maybe?) and a locked t series rear. had been that way for at least three owners, all of them hooligans. seemed to be holding up fine.
there are defintely bellhousings for W > 1G
i say use it till it breaks!
but dont put an LSD centre in it, cos i reckon it WILL break :D
Postby Coldspark » Sat Jul 10, 2010 1:39 pm
Brawler wrote:What gearbox do you have?
im thinking its w55 /hoping :P
ok name that Gearbox now :lol:
rollaholic wrote:i had a mark II with a 1ggze, w series box (55 maybe?) and a locked t series rear. had been that way for at least three owners, all of them hooligans. seemed to be holding up fine.
yea i was, but im planing out what will break if i buy this 1jz
Coldspark
Postby metal_sean_head » Sat Jul 10, 2010 5:38 pm
This one is definately a 'dave' IMO.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby KinLoud » Sat Jul 10, 2010 9:58 pm
box looks like W55/7/8
Ken
Postby rollaholic » Sun Jul 11, 2010 10:35 am
agreed
Postby Quint » Mon Jul 12, 2010 11:52 am
Looks like a 55 to me 57s are a wee bit thicker in relation to the sandwich plate.
Definitely 1G -> W bells around. Normally cheap too.
Quint
Postby KinLoud » Mon Jul 12, 2010 1:01 pm
Quint wrote:Looks like a 55 to me 57s are a wee bit thicker in relation to the sandwich plate.
Naaa - they look exactly the same... you can't tell until you count the input shaft turns vs output shaft in 1st and 5th gear
Postby ryanfels » Mon Jul 12, 2010 2:50 pm
Theres no such thing as a 1g - w50 only w55/57/58 etc.
thegreatestben wrote:It's lucky you arent a douchebag other wise I wouldn't help you :wink: :wink:
mark 2 gx61 2jzgte powered - viewtopic.php?t=72619&start=0
Discussion - viewtopic.php?t=72620
ryanfels
