AE111 Clutch replacement
Postby eskimo » Wed Jul 14, 2010 9:30 am
Hi,
Im looking to replace the clutch in my AE111 myself & wanting to know if its a relatively strait forward thing that I can do over a few days.
Are there any little things that I need to do/look out for when removing & installing the gearbox and associated parts?
Any tips would be appriciated.
JH
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby MR2BOY23 » Wed Jul 14, 2010 9:50 am
It's pretty straight forward. The torque settings on the flywheel bolts are all that matters, you don't need a manual/step by step guide for a job like this. Centering the clutch plate is sometimes a pain.. but nothing too difficult
MR2BOY23
Postby MR2BOY23 » Wed Jul 14, 2010 9:51 am
Are you going with OEM?
If you want I can get you a price on an exedy heavy duty clutch
MR2BOY23
Postby eskimo » Wed Jul 14, 2010 12:09 pm
Cheers, thought it wouldnt be huge job just a tad time consuming being that im doing it at home.
I have a clutch alignment tool so that sould solve that problem. Yea will be gettong a TGP one from Mark soon
Also can any one recomend somewhere I can get the flywheel skimmed?
JH
eskimo
Postby MR2BOY23 » Wed Jul 14, 2010 12:47 pm
Where are you located?
I get mine done at Autostop they do a good job
MR2BOY23
Postby eskimo » Wed Jul 14, 2010 5:29 pm
South Auckland, Sweeet!! there is a Autostop about 15mins from my house so will drop it off there when I get around to actually removing it...
eskimo
Postby rollaholic » Wed Jul 14, 2010 5:31 pm
not sure if AE111 are like this (dont think i've done a clutch on one yet) but on the AE101s the rear engine mount can be a pain to get out, fouls on various things. i've found the easiest way is to knock the studs out of it once you have unbolted them.
helpful hint #5487!
Postby Distrb » Wed Jul 14, 2010 5:46 pm
rollaholic wrote:not sure if AE111 are like this (dont think i've done a clutch on one yet) but on the AE101s the rear engine mount can be a pain to get out, fouls on various things. i've found the easiest way is to knock the studs out of it once you have unbolted them.
helpful hint #5487!
ae9x, ae101 & ae111 are all like that.
Easiest to notch the crossmember out so you can remove it with rear mount in place. then do as mentioned earlier and knock all the studs out and weld bolts in.
Some of the later ones have a stud in the crossmember also which you can knock out.
Distrb
Regular Poster
Postby shihad » Wed Jul 14, 2010 6:45 pm
i got a heavy duty extreme (extreme is the brand) clutch for blacktop for sale for 300 brand new retail 440 at bnt if ur interested.
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
