siren676 wrote:I have a 1998 toyota starlet n/a and its got a c140 gearbox (4 speed).
It is really useless at motorway speeds with engine doing 3100rpm @ 100kph which seems really uneconomical.
Can anyone recommend what gearbox i should be looking at swapping into it?
Also should i be looking at putting a new clutch in now or when i eventually put in a 5e engine?
BZG Wagon wrote:
Wouldn't be surprised if you found a 5 speed has the same final rato, just more gears in between.
Dell'Orto wrote:I wouldnt think so, most 4th gear ratios are 1:1, with an over driven 5th. Or it would at the very least have a different final drive ratio
ee904age wrote:Or "chuck some 20's on it bro"
