Who knows about Links?
Postby Boost_4_Life » Tue Jul 20, 2010 8:43 am
just wondering if this is any good for my standard 20V silvertop... wanting to get a bit of tuneability into the rally car before i start tweaking the motor. Someone I know has this link available but i know bugger all about it, tried the link website but could find much:
Link LEM, EPROM D42V5E
Daughterboard 2004/02
Mainboard Feb/04
Came out of a modded B18 Honduh. I think its set up for paired injection though. I can get my hands on it cheaply so wondering if its worth using in the 20V?? Can provide pics...
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby YeMs » Tue Jul 20, 2010 12:08 pm
that would be an older version 3 or 4.. im pretty sure you will have to have the mother board changed to run your engine as the older links were distributed pre programmed for engines and you couldnt change the trigger types etc.
Your local Hybrid Elite tech
YeMs
Postby Boost_4_Life » Tue Jul 20, 2010 12:35 pm
mm also suspecting not set up for VVT solenoid...
The rally beast
Boost_4_Life
Postby dnalunchie » Tue Jul 20, 2010 1:09 pm
whisper burning angel, he knows abit about them
EX:89 RS and GT Legacys, 90 EF9 Civic, 95 Integra R, 95 AE101, 90 ST185, 88 Accord, 87 3rdoor and 5door Swift hatch, 91 Pontiac Lemans, 80 Liftback Celica, 95 Hornet 250
Current: 90 3sfe Corona
dnalunchie
Postby Stu- » Tue Jul 20, 2010 5:11 pm
Version 5 by the looks - should be ok to use.
Project Thread
Stu-
Postby Dell'Orto » Tue Jul 20, 2010 6:32 pm
Would be V5 if its an 04 board
Re: Who knows about Links?
Postby matt dunn » Tue Jul 20, 2010 7:32 pm
So is a V5,
and will do VVT.
Postby Boost_4_Life » Tue Jul 20, 2010 7:53 pm
sweet cheers. I guess I'll have to contact link to find out if the sub board needs changing to suit 20V triggering
The rally beast
Boost_4_Life
Postby QikStarlie » Tue Jul 20, 2010 8:30 pm
will do if its been on a honda
QikStarlie
Postby matt dunn » Tue Jul 20, 2010 9:51 pm
You may or may not be in luck as they stopped the support for those a while back meaning no new sub boards, so unless they have some old stock of them....
But they may as the 20V sub board is common with most toyota's of that era.
Postby Boost_4_Life » Tue Jul 20, 2010 10:08 pm
Hmm i'll suss it out, may not be worth if i have to shell out for a sub board. i've got a couple of other options up my sleeve too hopefully.
The rally beast
Boost_4_Life
sub board
Postby ezy10s » Wed Jul 21, 2010 4:40 pm
I have a sub board to suit a 20v on my shelf if you end up needing one.
Member #244
Gone fishing until further notice
ezy10s
Postby Boost_4_Life » Wed Jul 21, 2010 5:05 pm
what sorta $$ mate??
The rally beast
Boost_4_Life
pfft
Postby ezy10s » Wed Jul 21, 2010 5:44 pm
the cost of a courier bag- has been sitting in my various garages for about three years now.
Member #244
ezy10s
