3SGTE Fuel Rail on Beams 3SGE
Postby loudstealthGT-Four » Tue Jul 20, 2010 11:42 pm
Can a fuel rail and injectors from a Gen3 3SGTE be bolted onto a Beams 3SGE and work without modifying anything.
Last edited by loudstealthGT-Four on Wed Jul 21, 2010 6:48 pm, edited 2 times in total.
loudstealthGT-Four
Postby Anth_555 » Wed Jul 21, 2010 8:23 am
no 3sgte injectors are side feed and 3sge injectors are top feed
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby Boosted_162 » Wed Jul 21, 2010 1:32 pm
Anth_555 wrote:no 3sgte injectors are side feed and 3sge injectors are top feed
Gen 2 and 3 are side feed, Gen 1 and 4 are top feed.
Postby Malcolm » Wed Jul 21, 2010 1:57 pm
but if you're swapping the whole rail and injectors then the top/side feed part becomes a bit irrelevant, it's more a question of whether the details in the head are the right spacing, match the injector seals (or if something which will fit can be swapped) and if the bosses for bolting the rail to the head are the same.
Postby loudstealthGT-Four » Wed Jul 21, 2010 6:47 pm
Malcolm wrote:but if you're swapping the whole rail and injectors then the top/side feed part becomes a bit irrelevant, it's more a question of whether the details in the head are the right spacing, match the injector seals (or if something which will fit can be swapped) and if the bosses for bolting the rail to the head are the same.
yip thats what im wanting to know, already knew about the top/side feed difference
loudstealthGT-Four
Postby nz_climber » Wed Jul 21, 2010 7:47 pm
Another difference is the beams 3sge engines (on the altezza anyway) run a blind fuel rail, so would need to change pumps and add a return fuel line too. Not sure about the head spacings sorry
nz_climber
Postby RomanV » Thu Jul 22, 2010 1:44 pm
What's the point in swapping the rail anyway?
Can just swap injectors for other top feed ones.
Postby loudstealthGT-Four » Thu Jul 22, 2010 7:23 pm
RomanV wrote:What's the point in swapping the rail anyway?
had a guy ask on trade me (who turboed his altezza) if they would fit as he wants to upgrade the factory altezza injectors
loudstealthGT-Four
Postby sergei » Thu Jul 22, 2010 7:54 pm
He could use GTT injectors, they will be straight fit.
