fpr problem
fpr problem
Postby gleem » Thu Jul 22, 2010 1:30 pm
Ive got a chinese fuel pressure reg. Ive cut the fuel line that goes to the standard fpr and put the unit in between. Ive taken the standard fpr of and ground the top down untill the spring came out. Put it back etc and now nothing shows up on the guage. even when i adjust it the needle does up and down a bit when the car is about to stall.
its stange the line going to it doesnt go through the fuel filter. that line goes some were else, i presume other end of fuel rail.
Is something wronf with this?
gleem
Postby sergei » Thu Jul 22, 2010 2:07 pm
What car is this?
Normally the fuel goes like this:
fuel filter => dampener (optional) => rail => pressure regulator => return line
You are supposed to replace original fuel pressure regulator with aftermarket.
What you could do is make an adapter out of spare pressure regulator and feed it to new regulator, which then relieves to the return line.
One way to make the adapter is to grind the top off (until what you are left is flange with a hole in the middle, and obviously bottom bit with O ring intact) and tap a fitting into that hole that connect to the fpr.
Postby gleem » Thu Jul 22, 2010 2:16 pm
rb20det. I was told if you grind the top off the stock one and take the spring out it is no longer a regulator and fuel can flow through freely?
gleem
Postby wde_bdy » Thu Jul 22, 2010 2:20 pm
If the fpr is at the end of the rail and you have put the new one in the return line, have you got it facing the wrong way? To test if the factory one is just bypassing as you expect it to pull the return line off the end and check that fuel flows out (into a container for safety) when you turn the key on and the fuel pump starts.
Callum
wde_bdy
Postby gleem » Thu Jul 22, 2010 2:25 pm
ok will do. so adjustable fpe should be in the return line at some point correct? google was surprisingly unhelpfull on this topic
gleem
Postby sergei » Thu Jul 22, 2010 2:32 pm
gleem wrote:ok will do. so adjustable fpe should be in the return line at some point correct? google was surprisingly unhelpfull on this topic
http://forums.nicoclub.com/how-to-set-y ... 14558.html
Postby gleem » Thu Jul 22, 2010 2:39 pm
sorted now thanks everyone. I had put the unit in the wrong way even after following instrutions(arrows and chinese writing) turns out arrows going in and out of the unit in the picture doesnt represent fuel flow haha
gleem
Re: fpr problem
Postby tsoob » Thu Jul 22, 2010 4:37 pm
gleem wrote:Ive got a chinese fuel pressure reg.
this worries me
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby KinLoud » Thu Jul 22, 2010 10:17 pm
I helped pick up a cefiro for a mate.
Luckily it had a flat battery when we tried to start it...!!!!!
Lucky because we opened the bonnet, connected jumper leads and then cranked it over...
There was a big spray of fuel!
Fuel was spraying out from the almost new aftermarket fuel pressure regulator in all directions from the gasket that sealed the 2 parts of the regulator together.
If it didn't need a jump start the car probably would have caught on fire while it was being driven to its new owner!
The guy selling the car said "yeah I thought that regulator was probably a piece of junk but it was cheap off trademe"
FARK!
Ken
Postby gleem » Thu Jul 22, 2010 10:31 pm
NO, it wont happen to me
gleem
Postby tsoob » Fri Jul 23, 2010 12:06 pm
gleem wrote:NO, it wont happen to me
this worries me
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Bling » Fri Jul 23, 2010 2:16 pm
Surely there are some parts you just don't skimp on :lol: :?
Postby Dell'Orto » Fri Jul 23, 2010 6:46 pm
BZG|Bling wrote:Surely there are some parts you just don't skimp on :lol: :?
Nah check out some of his other posts :lol:
Re: fpr problem
Postby 2jayzgte » Fri Jul 23, 2010 6:53 pm
this worries me
Yep those were my first thoughts when reading his post aswell.
2jayzgte
Re: fpr problem
Postby MAGN1T » Sat Jul 24, 2010 11:12 am
gleem wrote:Ive got a chinese fuel pressure reg. ?
But why though?
What's wrong with the stock one?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Re: fpr problem
Postby sergei » Sat Jul 24, 2010 11:56 am
But why though?
Steve
Absolutely nothing. He was scammed into thinking that it will give him extra 10hp or whatever.
Postby MAGN1T » Sat Jul 24, 2010 1:24 pm
If you've fitted a bigger pump and it outflows the stock reg, then the best fix is to do what the factory does on bigger motors.
That's to modify the pump circuit with a resistor that's switched out at higher loads.
Contrary to popular belief it's NOT just to make it run quieter, it's to save wear on the pump, to not outflow the reg and to not outflow the return line.
The factory way is always best because it's designed by engineers rather than aftermarket parts salesmen.
Steve
MAGN1T
Postby gleem » Sat Jul 24, 2010 5:40 pm
rb20det. Running slightly bigger pump and its got a few very upgraded bits so nissan specialist joe kyle recommended me to get one so i did (not chinese though) as it still may be running a little lean
gleem
Postby stolic » Sat Jul 24, 2010 6:37 pm
gleem wrote:rb20det. I was told if you grind the top off the stock one and take the spring out it is no longer a regulator and fuel can flow through freely?
did they tell you that, if the internal diaphram in the fpr leaks, it will send fuel pumpin out of your freshly grinded hole? AFAIK fpr's are sealed units for a reason.
surely a better option would be to spend $40 and get a proper adaptor like this...
http://www.trademe.co.nz/Trade-Me-Motor ... 857659.htm
sure it's D1 Spec, but it's gotta be safer. I'm all for cheap/free mods, but some corners should not be cut
stolic
