how to install lowered springs?
Postby 88.4ageGT » Sat Jul 24, 2010 12:19 am
how to put in lowered springs in a ae92 corolla gt
looking for tips
and basicly how to do it
AE92 4age GTi
Building 3sge ae92 race car
Malcolm wrote:I didn't know they had maths on waiheke
88.4ageGT
Postby Bling » Sat Jul 24, 2010 1:20 am
What tools you got?
Postby 88.4ageGT » Sat Jul 24, 2010 1:58 am
most things
AE92 4age GTi
88.4ageGT
Postby Emperor » Sat Jul 24, 2010 3:49 am
A spring compressor will be handy, without.. Pretty risky job
Emperor
Postby Infinite » Sat Jul 24, 2010 8:27 am
c clamps work to compress springs but sucks thats why i got spring compressors lol
Lots
Infinite
Postby Mr Revhead » Sat Jul 24, 2010 11:13 am
Best tip, get someone who has done it before to help you. Don't get them to do it, get them to assist you so you learn :wink:
Postby tsoob » Sat Jul 24, 2010 5:32 pm
its pretty straight foward,
you will need a decent socket set, spring compressors, jack etc.
Remove the wheels, take the brake lines off the strut, remove the sway bar (do both sides so you dont fight the sway bar)
Remove the 2 big bolts to remove the strut from the hub.
Take the 3 bolts off the top, and remove your shock.
Compress the spring, and remove the top nut. change the pring over and do the reverse to put it back together.
Failing that bring the car to my workshop.. best record for this job with 2 of us doing it is a little over 40 mins :)
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby h8wrxs » Thu Jul 29, 2010 6:59 pm
dont need spring compressor with lowering springs, just need a mate to put weight on the spring when your undoing/doing the top nut up
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby Mr Revhead » Thu Jul 29, 2010 7:12 pm
h8wrxs wrote:dont need spring compressor with lowering springs, just need a mate to put weight on the spring when your undoing/doing the top nut up
Not true for all applications. DO NOT ATTEMPT
Postby matt dunn » Thu Jul 29, 2010 7:41 pm
Fitting springs is an easy job,
Drive it to the local shock shop,
and come back in an hour or two.
No stress, no problems and quite safe.
$150 inc a full wheel alignment.
Postby deaf_rattle » Thu Jul 29, 2010 7:47 pm
just pick up some fat chicks.
you will not only lower your car, you will take some of that shit off the street.
Postby h8wrxs » Fri Jul 30, 2010 12:25 am
mmm fair call i have seen it done wrong, springs do come out of the strut REALLY fast if youre not careful lol
h8wrxs
Postby spannersnz » Fri Jul 30, 2010 1:07 am
Can undo top of shock while strut is in car, then jack car up. Weight of the car holds it from exploding, not unsafe at all. Do the reverse to put new ones in.
But you are much better off with spring compressors
spannersnz
Postby Mr Revhead » Fri Jul 30, 2010 9:41 am
Guys.
The OP is doing this for the first time.
Some of the things you are suggesting are not for the first timer to attempt....
Postby AE86less » Fri Jul 30, 2010 7:16 pm
Yah. Hand in cast for 4 weeks due to tearing the ligament between thumb and index finger again when the spring caught my thumb on the way out.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby ch4ng » Fri Jul 30, 2010 7:48 pm
There ya go
Learn from someone elses mistakes
If ya doin stuff for the first time it pays to learn it the right way
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby Subway » Tue Aug 03, 2010 8:49 pm
tsoob wrote:its pretty straight foward,
This, had some new shocks installed by Nick, would recommend
Subway
