suprised not to find this on net?
i need to know the axle length on a stock axle,
Simon86 wrote:Presumably from the splined end, to where?
I have some out so can measure for you tonight.
rollaholic wrote:LSD and non LSD are different length
about 5mm from memory (with no LSD being longer)
you cant use non LSD axles in standard LSD heads without bad results (found this out the hard way) though apparently some aftermarket centres accept either type
rollaholic wrote:yep i realise what you are after
i was just trying to be helpful / save potential problems
Simon86 wrote:From hub face to end of spline 684mm +/- 1mm
They are facelift if it makes a difference...
