4a-fe c56 same as blacktop c56?
Postby gmacrae » Sat Jul 31, 2010 11:45 am
Hey guys. Im trying to get a decent gearbox in my corolla and basically want a low km blacktop 5 or 6 speed box. I've found one from an ae111 levin 4a-fe, I understand it will bolt up fine but are there any differences internally to the blacktop c56?
gmacrae
Postby B1NZ » Sat Jul 31, 2010 11:55 am
should be the same
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Mr Revhead » Sat Jul 31, 2010 11:57 am
Im pretty sure the ratios are different. infact.... I will say they ARE different.
Postby QikStarlie » Sat Jul 31, 2010 12:11 pm
from what ive found c56, c52 etc relate to the ratios. but the final drive can be different
for example. you can get a c56 in both a starlet glanza and ae111 but the starlet has a 3.7 and the ae111 has a 4.3. actual gear ratios are the same, and obviously the case is different as well
QikStarlie
Postby strx7 » Sat Jul 31, 2010 1:46 pm
yes C56, or C52 etc refers to the ratios of the actual gears themselves and has no bearing on the diff ratio in the box at all.
Postby pc » Sun Aug 01, 2010 12:15 am
You can figure out what gearset & diff ratio it has by tuning the input shaft and counting the turns compared to the output.
Just jam a piece of thick wire, or a thin screw driver into the diff where the axles go to lock both sides of the diff together. Then count how many revolutions it takes on the input shaft to equal one revolution on the output, do that in each gear.
Wikipedia have the ratios http://en.wikipedia.org/wiki/Toyota_C_transmission
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby gmacrae » Tue Aug 03, 2010 9:54 pm
cheers guys... so a glanza has a c56 with 3.7 final drive? Thats cool... has anyone used one of them in a corolla/levin with the 4age bell? That would drop the revs down a fair bit
gmacrae
Postby Mr Revhead » Tue Aug 03, 2010 10:01 pm
Mr Revhead wrote:Im pretty sure the ratios are different. infact.... I will say they ARE different.
And having just checked I will now say I am sure they are different. According to the TRD Levin Trueno Bible.
if you want an A series c box with the 3.7 final drive, grab one from an ae110
Postby TRD Man » Tue Aug 03, 2010 11:13 pm
What the bible, and a host of other references tell you Warwick is that the ratios in the boxes on 4AGE & 4AFE powered Levin are different. It doesn't state that they are both C56's.
TRD Man
Postby Bling » Tue Aug 03, 2010 11:50 pm
Gf's '96 Trueno (4afe) has a C50, what's the story? They came out with different gearboxes? :?
Postby Mr Revhead » Wed Aug 04, 2010 8:42 am
TRD Man wrote:What the bible, and a host of other references tell you Warwick is that the ratios in the boxes on 4AGE & 4AFE powered Levin are different. It doesn't state that they are both C56's.
I'm not aware of ae11#s with c52s?
Postby Leon » Wed Aug 04, 2010 8:44 am
So if I have a silvertop powered Corolla, and I want a nice rev happy diff ratio, what should I be trying to burgle a gearbox out of?
(current gearbox is original to car so ae92 gt sedan, previously bigport).
Postby TRD Man » Wed Aug 04, 2010 9:04 am
Mr Revhead wrote: I'm not aware of ae11#s with c52s?
I didn't say they had C52's.
BZ/Bling has just given an example of one with a C50 which would relate to the differing ratios you're quoting.
TRD Man
Postby Mr Revhead » Wed Aug 04, 2010 9:05 am
True...
Then maybe the Op isn't after a c56 at all :P
Postby gmacrae » Wed Aug 04, 2010 9:46 am
Mr Revhead wrote:True...
thats what im thinkin...
gmacrae
Postby QikStarlie » Wed Aug 04, 2010 5:42 pm
Leon wrote:So if I have a silvertop powered Corolla, and I want a nice rev happy diff ratio, what should I be trying to burgle a gearbox out of?
so it should have c52 4.3, so best you can do is get a c56 4.3 from a facelift silvertop or blacktop etc. more evenly spaced ratios
QikStarlie
Postby 85AW20v » Wed Aug 04, 2010 10:27 pm
Does any C5* have a final drive lower than 4.3? Or would anything else fit?
See ya
Simon
85 MR2 20v
85AW20v
Postby gmacrae » Thu Aug 05, 2010 8:36 am
85AW20v wrote:Does any C5* have a final drive lower than 4.3? Or would anything else fit?
aparently a c56 from a glanza turbo, or a c50? from ae110
gmacrae
Postby pc » Thu Aug 05, 2010 6:48 pm
Not necessarily 4.3. I have found a couple of 4.059 ratios in C52s. Best to measure as toyota played mix-n-match lots.
But yes, the best you will get as a bolt in replacement with no modification is a C56 with 4.3 diff ratio.
With a rev limit of 7800 that will give the following top speeds in each gear: 62.05 103.18 141.13 190.54 241.04
red car
Manfield - 1:24s
pc
Postby Mr Revhead » Thu Aug 05, 2010 6:56 pm
pc wrote:241.04
I know you mean theoretical, but seeing that number there still makes me lol :P
