Tyre Choice - 195/55 or 195/50
Postby Simon86 » Sun Aug 08, 2010 8:37 pm
I know the obvious difference, but is there something i'm missing when it comes to selecting one or other of the above sizes?
The car is an AE86 and will be used for trackdays and hillclimbs.
The rims are 15x8.5
Simon86
Postby Dell'Orto » Sun Aug 08, 2010 8:49 pm
One of the tyre guys will pipe up, but AFAIK the main difference is the rolling diameter, which will throw out your speedo reading
Postby Simon86 » Sun Aug 08, 2010 9:13 pm
Yes - aware of this also - 50 series is near on the same as stock and 55 series is 3% bigger.
Simon86
Postby strx7 » Sun Aug 08, 2010 9:13 pm
if the rims are 8.5 inches wide, I would have thought you'd be looking at around 215 or 225 width tyres? or are you going for that GHEY stretched tyres look?
Postby Simon86 » Sun Aug 08, 2010 9:40 pm
195's on a 8in rim were the size previously run and in my opinion the best size for a NA AE86. Would consider 205's but have concerns about fitting them under lipped guards. 225's would look like balloons.
Simon86
Postby strx7 » Sun Aug 08, 2010 9:58 pm
i currently have 225's on 7 inch wide rims on my 4wd 100 series club car., they'd be better on 7.5's or 8's
If you are worried about them fitting under the guards run a narrower rim......... :roll:
Postby Rick » Sun Aug 08, 2010 10:28 pm
If you are going to be running those size rims on the road for a cert the minimum width tyres are 225mm wide.
Postby Simon86 » Sun Aug 08, 2010 10:36 pm
Really? Where did you get that information from? That makes me slightly nervous as there's no way I'll fit a 225.
Simon86
Postby RomanV » Sun Aug 08, 2010 10:39 pm
Postby Simon86 » Sun Aug 08, 2010 10:46 pm
That's unfortunate.
Simon86
Postby nz_climber » Sun Aug 08, 2010 11:46 pm
Also I would be reading (and taking note) what the tyre manufacture says
For the sizes given above bridgestone states 5.5inch - 7inch Permitted (for a RE11) So going an extra 1.5inchs on top of that won't be great idea.
nz_climber
Postby rollaholic » Mon Aug 09, 2010 8:40 am
remember the above link is a rule of thumb and is applied at the certifiers discretion, so as long as it looks reasonably respectable i dont think you'll have a problem
tasteful stretch ftw
dont let all the old fogeys on TS put you off :P
Postby TRD Man » Mon Aug 09, 2010 10:49 am
It's not a matter of being "old fogey's". It's about what's practical or correct.
The LVV chart posted looks pretty good to me and I certainly wouldn't be stretching a 195 tyre onto an 8.5" rim.
On our FWD Corolla we ran 205/50's and 205/55's on 7" rims which are about right.
In terms of the rolling circumference, don't underestimate the effect of this. A lot will depend on your gearing.
I would think if you are running std drivetrain 50's would be the go.
TRD Man
Postby Malcolm » Mon Aug 09, 2010 11:20 am
it's funny how stuff like this is. I can't afford/don't want to spend the money on buying wide wheels for my car (if anyone ever sees any 4x100 8" wide rims on trademe, let me know ;) ), so I've always tried to squeeze the widest tyres I could onto my 7" rims, but then you have people who get big fat rims and want to fit the skinniest tyres possible onto them.
Also the thread on old school is pretty crack up, using an F1 as an example to show stretched tyres are safe :lol:
Postby Mr Revhead » Mon Aug 09, 2010 11:23 am
Careful, you'll get abused :P :lol:
Postby FLAWLES » Mon Aug 09, 2010 12:06 pm
Mr Revhead wrote:Careful, you'll get abused :P :lol:
lol
nah cant be $&#$%
your safe haha
but yea each to there own i spose
FLAWLES
Postby Malcolm » Mon Aug 09, 2010 1:03 pm
I'm always happy to enter into friendly technical debate on such matters :)
Postby tsoob » Mon Aug 09, 2010 1:30 pm
go the 195 50, speedo etc. 205 50 would be ok as well
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby rollaholic » Tue Aug 10, 2010 8:41 am
TRD Man wrote:It's not a matter of being "old fogey's". It's about what's practical or correct.
i dont think an 80s corolla is going to be at the pointy end of any field, unless the field is otherwise made up of 70s corollas. many, many cars have been running stretched tyres for many, many years. i have seen a few examples of it causing problems, but it seems to be only in extreme cases, both usage and stretch.
whatever benefits or penalites it may impose on your lap times are largely irrelevant imo, unless its a dedicated track car and you care about tenths of a second. if the owner likes it and has fun, whats the problem?
the old fogeys comment was largely tongue in cheek :D
Postby Simon86 » Tue Aug 10, 2010 5:09 pm
I have run 195/55's on 15x8 rims in the past with zero problems - the sidewall is virtually vertical, and was certified that way. Even prior to the new legislation there was still a cert requirement for the right section width tyre to be fitted to the rim, now it is clearly defined by way of a table.
However I think it is aimed more at people stretching 185's on a 9.5in rim or similar, but a line has to be drawn somewhere and the manufacturers 'recommendations' are probably a good place to start.
Simon86
