sub wire?
sub wire?
Postby 88.4ageGT » Wed Sep 01, 2010 9:19 pm
What size wire do you use when you connect a sub?
AE92 4age GTi
Building 3sge ae92 race car
Malcolm wrote:I didn't know they had maths on waiheke
88.4ageGT
Postby DeeCee » Wed Sep 01, 2010 9:22 pm
what's the sub and amp? 12 and 14 gauge is normally sufficient
GT Four Adovansu
DeeCee
Postby 88.4ageGT » Wed Sep 01, 2010 10:09 pm
what if you connect the sub to a normal stereo?
AE92 4age GTi
88.4ageGT
Postby siren676 » Wed Sep 01, 2010 10:32 pm
I don't think an ordinary head unit puts out enough power to run a sub.
If you tell us what sub and head unit you have got we may be able to tell you what you can do.
siren676
Postby 88.4ageGT » Wed Sep 01, 2010 11:13 pm
I got a 12 inch sub nd 4 speakers
but my stereo in my car doesnt have a rca port i think
so i cant run an amp i think?
so i have two wires running to the boot of the car
they are ment for the rear speakers
but i thought i would just hook up a sub nd 2 speakers to each wire?
on the left and right as i have tryd this on a normal stereo nd it has worked
AE92 4age GTi
88.4ageGT
Postby Alex B » Wed Sep 01, 2010 11:35 pm
Postby Bling » Wed Sep 01, 2010 11:46 pm
^^ :lol:
88.4ageGT wrote:I got a 12 inch sub nd 4 speakers
Unless you have no money, go see a professional sounds installer. I really don't think it's a wise move to touch it yourself if you're having to ask the above questions.
You can get amps that will run via speaker wires. But ummm well, get a pro to do it. The fact your head unit doesn't have any RCA's probably means its rubbish in any case.
Sub off of headunit is the funniest thing i've heard in a while though. No, just no.
Do some research on www.google.com on car audio and learn a thing or two about it before even touching it :)
Postby siren676 » Wed Sep 01, 2010 11:52 pm
^^^Agreed^^^
But on a serious note i think i saw a item on jaycar which converted normal speaker wire to rca plugs/output.
The only way to tell if your stereo has rca out is to take it out and see if it has red and white female a/v style plugs on the back.
I will try to find a basic stereo wiring diagram to show you how it should be set up.
siren676
