oil temps during track thrash???
Postby d1 mule » Tue Sep 14, 2010 10:35 pm
finally had a proper play/ drift in my ae70 today after a long wait,
just curious as to what oil temps i should be expecting to see??
its a 4agte with an oil cooler, but the cooler isnt really in the optimum place for air flow.
was seeing about 120 degrees C all day, the water temp was pretty hot most of the day too but hopefully some new fans i just brought will fix that.
d1 mule
Re: oil temps during track thrash???
Postby sergei » Tue Sep 14, 2010 10:58 pm
d1 mule wrote:finally had a proper play/ drift in my ae70 today after a long wait,
Fans will make it worse under speed (they are there only when stationary/moving slow). 120C oil temp is pretty good for track.
Postby touge_ae101 » Tue Sep 14, 2010 11:32 pm
hate to know what temps you would be seeing with no cooler eh?
was told by a hydraulics guy that i wouldn't want the oil getting above 100 C as it starts to break down. but it seems awfully low seeing as marks (1I1) corolla sees 120ish just driving around town. makes me want to put a oil temp guage in my car. hmm :?
may i ask where your oil cooler is placed?how un-optimal is it?
touge_ae101
Postby d1 mule » Wed Sep 15, 2010 12:49 am
the oil cooler is mounted right up front but the monster of a '80s bumper is right in the way
the cooler is directly behind the bumper in this pic
hopefully i can whip up some sort of ducting before saturday which will hopefully help airflow to the radiator. the fans are thermostacically controlled if that makes a difference
d1 mule
Postby escortman » Wed Sep 15, 2010 8:17 am
na fans dont do anything once your moving, if its getting hot whilse moving and giving it shit, then possibly water pumps on way out (corroded/missing fins) or the radiator is just not big enough
4x4 toyota blizzard offroader
escortman
Postby 1I1 » Wed Sep 15, 2010 9:10 am
touge_ae101 wrote:but it seems awfully low seeing as marks (1I1) corolla sees 120ish just driving around town. makes me want to put a oil temp guage in my car. hmm :?
90degrees is pretty common for just town driving. 110degrees open road driving :wink:
TRD Clicky >>Here
1I1
Postby FANGIN » Wed Sep 15, 2010 9:29 am
Oil temp in the bosses R35 hit 123 decrees c when we took it round Puke.
Made him a tad nervous so he has upgraded his cooler
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
FANGIN
Postby touge_ae101 » Wed Sep 15, 2010 9:42 am
ah mybad your temp gauge is hard to read sometimes. lol.
i used to know when my oil was getting too hot in the 4afe cause the oil press gauge used to flicker when it giving prolonged periods of thrashing. haha new engine doesn't do it though
looks like a bit of airflow would help a bit with the cooler. can't drop it down a bit to pick up some airflow under the bumper?
touge_ae101
Postby cat007 » Wed Sep 15, 2010 7:01 pm
120C is dam hot for oil.
You want to be between 90-100 if you can. Any lower and it starts to be a little too viscous, any higher and the opposite....
There's a reason why oil cooler thermostat's OPEN at around 80-85C....
Get a massive oil cooler and then buy one of these:
http://www.perma-cool.com/Catalog/Cat_page14.html
Postby 1I1 » Wed Sep 15, 2010 7:08 pm
cat007 wrote:120C is dam hot for oil
Hate to think what its like should say the oil get to 135degrees :D
TRD Clicky >>Here
1I1
Postby cat007 » Wed Sep 15, 2010 7:19 pm
135 is still acceptable but I wouldn't want to have mine that high.....
Postby matt dunn » Wed Sep 15, 2010 8:13 pm
We have had diff oil temps over 200, and i wouldn't worry with engine oil temps of 125c or less.
Postby Bazda » Wed Sep 15, 2010 8:24 pm
120 deg is quite common, if its going higher I suggest you run a better oil that can handle those temps like Motul, Elf etc.
Postby d1 mule » Wed Sep 15, 2010 11:23 pm
ill keep a better eye on it on saturday, ill rig up a water sparyer for the rad tomorrow off the washer bottle. but hopefully the flush and new anti freeze/boil will help.
oh and the water pump is brand new, done dyno time and maybe 40 laps of ruapuna.
d1 mule
Postby DRFTIN » Thu Sep 16, 2010 12:39 pm
yeah what oil are you using?
i used to use the castrol out of the tank at work but it didnt seem to like the thrashing so switched to 10w60 edge. im only going by pressure but pretty sure its handling the temperatures a lot better
maybe the oil is trying to save us from the fluro? :p
DRFTIN
Postby KinLoud » Thu Sep 16, 2010 12:46 pm
Where is the temperature probe?
Is the gauge accurate? Has it been calibrated?
There are a number of factors that could affect accuracy of your oil temp readings.
If you have concerns upgrade to fully synthetic as it copes better with high temps,
Postby Flannelman » Thu Sep 16, 2010 12:46 pm
http://www.elephantracing.com/techtopic ... rature.htm[url][/url]
Found this.
And just to point out, 100C is 212F.
Flannelman
formerly known as Affroman
Postby cat007 » Thu Sep 16, 2010 1:31 pm
KinLoud wrote:Where is the temperature probe?
Correct me if I'm wrong, but I'm pretty sure the oil temp sensor should be in the sump?
Postby sark.inc » Thu Sep 16, 2010 6:54 pm
d1 mule wrote:ill rig up a water sparyer for the rad tomorrow off the washer bottle.
i would say rigging up a sprayer would be a bad idea, you would be introducing cold oil to a hot engine, thermal shock is never good.
sark.inc
Postby cat007 » Thu Sep 16, 2010 7:02 pm
Not including the fact that sprayers are probably frowned upon on tracks because you're going to be introducing water to a possibly dry tack.
