BT vs ST Cams
BT vs ST Cams
Postby Lurkin » Sat Oct 09, 2010 12:40 pm
Any ideas on the difference between them/ any point changing to BT cams?
Past casualties
1986 4age liftback (sold)
1985 4age aw11 (well crunched)
1993 ae101 gt apex levin (sold)
Lurkin
Postby Adamal » Sat Oct 09, 2010 3:00 pm
Given that the difference between the 2 engines is something like 10hp, and there are a number of differences (high compression, MAP instead of AFM), I doubt there would be a difference in putting them in.
Postby ATAl » Sat Oct 09, 2010 4:44 pm
Have a squiz at the bottom of this page http://www.billzilla.org/4agstock.htm
ATAl
Postby headshotnz » Sat Oct 09, 2010 6:33 pm
From memory BT has a slitly higher life on the intake, from memory the exhaust is the same as a ST.
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby matt dunn » Sat Oct 09, 2010 8:12 pm
headshotnz wrote:From memory BT has a slitly higher life on the intake, from memory the exhaust is the same as a ST.
There is also a 5 deg timing difference between the intake cams.
Users browsing this forum: Bing [Bot] and 4 guests
