dnalunchie wrote:I don't want to discourage you but for the amount you will spend doing it you would be better off forging the 4age and turboing that, it has been proven time and again here that they can easily produce in excess of 400hp atw.
Quirky wrote:Ive seen an AE82 Hatch with a 3sgte front drive.
Seemed interesting, but it made 220kw at the wheels.
You can achieve the same power from a turbo 4a so probably not worth it.
sergei wrote:on other hand the 4AGTE will be a hand grenade with that sort of power unless you spend twice as much as 3SGTE conversion will cost.
matt dunn wrote:Kw for Kw I would say a 3SGTE is much more of a hand grenade than a 4AGTE at the same hp.
iOnic wrote:matt dunn wrote:Kw for Kw I would say a 3SGTE is much more of a hand grenade than a 4AGTE at the same hp.
What makes you say that?
matt dunn wrote:sergei wrote:on other hand the 4AGTE will be a hand grenade with that sort of power unless you spend twice as much as 3SGTE conversion will cost.
220kw from a 4agte is not even a push.
soopachargen wrote:this is a good build
http://www.twobrutal.co.uk/forum/showthread.php?16162-Woodsport-3s-gte-Corolla&highlight=ae101
KIPH8N wrote:Has anyone done swaped a 4age with a 3sgte in a levin. Fwd gearbox. Need some info thanks. Mounts n etc
Users browsing this forum: No registered users and 35 guests
