Truenotch wrote:RomanV wrote:As in, theoretically I know where the hole is, I know what I'm supposed to plug it with, but that's about it?
Well in this case you actually had a hole to plug, but didn't go there .
2RZFE with a turbo anyone
RomanV wrote:Well actually, I prefer not to plug the hole because I like how fluid gushes out of it, onto my head.
Babz wrote:
13b - too expensive to maintain and build but always wanted one
TRD Man wrote:Of the 3 engines you've indicated you're choosing between, and your desired power output, the turbo SR20 is the only realistic option.
You simply won't get there with a 3SGE and if choosing between two turbo engines/drivetrain combos why wouldn't you use the more modern with more readily available and reasonably priced components?
FANGIN wrote:Hate to be a hater - SR20. Best bang for buck.
fuel wrote:just putting this out there
