Heat paint for brake hard lines?
Postby cat007 » Mon Nov 22, 2010 5:43 pm
Hi peeps
A couple of my brake hard lines out of the master cylinder run a bit close to my wastegate for my liking.
Is there a brush on paint I can get to apply to the brake lines that will help prevent the heat from penetrating through them and therefore into the brake fluid?
Hunt
Postby rollaholic » Mon Nov 22, 2010 6:10 pm
i'd have thought a heat shield would be more effective, air gaps ftw
Postby cat007 » Mon Nov 22, 2010 6:11 pm
rollaholic wrote:i'd have thought a heat shield would be more effective, air gaps ftw
Yeah same except there are too many angles to make a heatshield that doesn't look like complete arse lol
Postby Malcolm » Mon Nov 22, 2010 6:24 pm
you can buy heat resistant sleeving, I'm not sure who sells it but I'd start with places like Alert, GSS etc. Would definitely be the best option in this case, realistically paint isn't going to make much of a difference.
Postby Bling » Mon Nov 22, 2010 6:37 pm
I'd rather have it look like arse than melt my brake lines :lol:
Postby Bazda » Mon Nov 22, 2010 6:41 pm
Silver Fyre foil is what you need. Alert Motor sport
Postby cat007 » Mon Nov 22, 2010 10:56 pm
Bazda wrote:Silver Fyre foil is what you need. Alert Motor sport
Thanks Barry. I'll give them a call tomorrow. Wonder if that stuff comes in small enough diameters - guess we'll see :)
Postby Bazda » Mon Nov 22, 2010 11:09 pm
I actually duno if they have the silver fyre foil, but they prob give you this stuff which should be good enough.
http://www.alertmotorsport.com/Product/Firesleeve/1592
But really you want this
http://porterfield-brakes.com/images/pr ... _50_49.BMP
Postby cat007 » Tue Jan 11, 2011 9:56 pm
Went with this stuff from Alert Motorsport
Should do what I ask of it I think.
Postby Bazda » Tue Jan 11, 2011 10:48 pm
that stuff is ok.
Didnt stop enough heat from my exhaust area to my oil lines as when I took the orange sleeve off, the oil lines had already started to melt :S.
So I switched to the silver fyre foil as it actually reflects the heat.
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
