allencr wrote:Is there actually valve between the LR and RR brakes or just a T?
If it doesn't have a problem between the F & R where the valve is plumbed in, then it isn't a valve problem!
BZG|Bling wrote:Do cars with ABS use the same valves?
eg ae111 abs
ae111 non abs?
TRD Man wrote:Old Toyota brake hoses (about the age of AE101) have been known to collapse internally causing a blockage which will effect the balance.
It is far easier, and less costly, to check this before the proportioning valve.
