Exedy clutch problems
Postby eskimo » Tue Nov 30, 2010 11:21 am
Ive had problems with them slipping from out of the box as well & they didnt want a bar of it so cut my losses and wont be buying another one ever again.
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby Tagged » Tue Nov 30, 2010 11:34 am
thanks for the detailed image and replies!
looks like exedys got some issues.....
Tagged
Postby Adamal » Tue Nov 30, 2010 12:11 pm
They're saying they tested it and it is holding pressure as it should. I might take it somewhere else along with my old pressure plate and get the both tested
Postby shihad » Tue Nov 30, 2010 12:14 pm
in my experience and everyone I know exedy never had a problem. extreme clutchs on the other hand.........
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby ryanfels » Tue Nov 30, 2010 1:02 pm
Ive used a few Exedy clutchs now and ive never had a problem
thegreatestben wrote:It's lucky you arent a douchebag other wise I wouldn't help you :wink: :wink:
mark 2 gx61 2jzgte powered - viewtopic.php?t=72619&start=0
Discussion - viewtopic.php?t=72620
ryanfels
Postby Akane » Tue Nov 30, 2010 1:48 pm
Adamal wrote:They're saying they tested it and it is holding pressure as it should. I might take it somewhere else along with my old pressure plate and get the both tested
I think their way of testing it is pushing the springs down with their thumbs and then gives it the green light.
Postby Adamal » Tue Nov 30, 2010 7:40 pm
Well, they do have a pressure tester, and it came out the same with my new one as my old one. They said that they think there has been some preload on the bearing causing it to slip, which is bullshit, as you can easily move the fork with your finger and feel it make contact with the diaphragm of the pressure plate.
They said "Hey, we'll give you another one, but it'll do exactly the same thing". Told my mechanic that and he said "Yep, gettit. It'll be fixed tomorrow.".
Postby allencr » Tue Nov 30, 2010 8:53 pm
Can you please take a pic or Measurement of the disk & clutch to see the disk thickness and the distance from the flywheel to the pressure plate?
Stepped flywheel with a different level between the friction surface and the pressure plate mount? A rule of thumb is that the distance between the PP's surface and the flywheel should be 1/2 the thickness of the disk.
allencr
Postby Adamal » Tue Nov 30, 2010 9:18 pm
I've already said that its not a stepped surface, its flush :P and I don't have the gear with me, so can't measure it. Clutch plate was about 7.8mm or something though
Postby THA SHZ » Wed Dec 01, 2010 11:51 am
never mind we have figured it out , does anyone have a 5 bolt nose cone that sits overtop of the shaft and semi holds the bellhousing to the box ?
THA SHZ
Postby Adamal » Wed Dec 01, 2010 2:55 pm
Have found one, wrecker is connecting mechanic to confirm that the part number is right. Should be, fingers crossed
Postby XS1V » Thu Dec 02, 2010 9:01 am
Better apologize to exedy lol 8)
Brad
ST205 Group A Rallye #2363
XS1V
Postby Adamal » Thu Dec 02, 2010 10:35 am
XS1V wrote:Better apologize to exedy lol 8)
Brad
Nahh.
Postby tsoob » Thu Dec 02, 2010 12:22 pm
Brad
Nahh.
LIKE!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby allencr » Thu Dec 02, 2010 1:11 pm
If it was the bearing retainer tube that is too long & has been keeping it slightly disengaged, I think that the PP's fingers would have been pretty chewed up & nasty looking the first time you removed it. Were they?
allencr
Postby Adamal » Thu Dec 02, 2010 1:32 pm
Not anymore than you'd expect one that comes out to be
Postby Bazda » Thu Dec 02, 2010 1:34 pm
meh get a twin plate :D
Postby Adamal » Thu Dec 02, 2010 1:53 pm
Bazda wrote:meh get a twin plate :D
Believe me, I'd LOVE to!
Postby shihad » Thu Dec 02, 2010 2:09 pm
viewtopic.php?t=81763
LOl he doesn't have 4age thread confusion my bad.
shihad
Postby THA SHZ » Thu Dec 02, 2010 4:39 pm
allencr wrote:If it was the bearing retainer tube that is too long & has been keeping it slightly disengaged, I think that the PP's fingers would have been pretty chewed up & nasty looking the first time you removed it. Were they?
also depends how long ago they welded it and whether they machined the bearing down to suit or not , our last option is to machine the snout , very last option .
THA SHZ
